clutch problem
has anyone ever heard of a pilot bearing siezing on the main input shaft and causing the clutch to act as if it isn't disengaging. I inspected the disc and all hydrolics. the springs are still in the disc and when the pedal is pressed, the disc appears to be moving properly. haven't remove trans yet to inspect, but the suggestion was made that the pilot bearing may have siezed.
