"HELP"transmission faliure?
My EK has been acting funny since my Changed my clutch,I have a CTR trans with the oem LSD.I changed the Fly wheel,Pilot bearing an throw out. Broke in the clutch just right.but its vibrating like crazy! Thought it was my axles, Changed my axles . Still the same thing! so right now, I jacked up my car an spun the wheels by hand, an only one wheel spun. Is'nt the other suppose to spin in the opposite direction?* I did it in on both sides an ,got the same results? Is this causing my problem?
when im accelerrating in low rpms then lightens up .Oh, i didnt have the car in gear when i was rotating thw wheels , put it in gear an fixed that problem. I have 99 SI axle on my driver side.there is some play where the female end meets the drive shaft, Could i have bought a broken axle?
Found out my Fly wheel could be the problem .Its brand new though.Its an ACT street lite with the si clutch .I herd that the fly wheel is not "true"? i didnt have it surfaced ,can that have been my problem? Any one with knowledge of this being the problem.
Andyroo
Jul 23, 2008 01:06 PM
Sehc Tib Alli Zerif!!!!!
Apr 18, 2006 01:15 PM
