Water leaking just behind glove department
I just want to know if any DA owners ever had water leaking behind the glove department. Usually after a rain storm, a small amount of water would gush through behind the passenger glove department. Now that it is winter, I warmed up my car and heard, what I think would be ice clinking around and water gushing out. Any DA owners ever have this problem and how would you fix it? I don't drive my car often enough in the winter to keep the car warm enough not to form ice.
A how to on how to fix it
https://honda-tech.com/forums/acura-integra-6/dyi-da-passenger-waterleak-fix-pics-2472431/
https://honda-tech.com/forums/showthread.php?t=2472431
up, because my car leaks too. I want to find out if its my windshield moldings or that before I spend money on the moldings that cost more.
I have a leak but on the driver's side, same diagnosis, just on the other side or is it something completely different?
I used just about a whole tube of honda bond in the open area under the cowling. Be sure to seal up the cowling in the immediate area with more honda bond. You won't be able to see much into the gaping hole or inlet for the a/c - heater so you'll have to feel your way around the area. just apply the stuff liberally.
This worked great for me. Very cheap and easy to fix too.
http://www.g2ic.com/tegtips/interior/15.html
Dekorum
18
Sep 28, 2010 07:55 AM
PatrickGSR94
Jan 30, 2005 02:38 PM
