Battling OBDII
Old Aug 9, 2002 | 08:29 AM
lildrgn2.0's Avatar
New User
Default Battling OBDII
OK. Since my 96 is OBDII, is it possible to get the ECU chipped or reprogramed to get rid of the 7200 Rev Limit? I am figuring if I get everything that I am planning, then I should be able to get power past $7200 safely if I get rid of the limiter.
any ideas?
Thanks again.
Old Aug 9, 2002 | 08:55 AM
Spade's Avatar
Default Re: Battling OBDII (Lildrgn)
No. OBDII is not programable.
Must convert to OBDI and use a hacked OBDI ECU.
Old Aug 9, 2002 | 09:05 AM
lildrgn2.0's Avatar
New User
Default Re: Battling OBDII (Spade)
aaaaaaaaaasssssssssssssssssssssssss
so does any one want to instruct me on what i need in order to convert? and how difficult this is going to be... and how much its going to SUCK?
[Modified by Lildrgn, 6:06 PM 8/9/2002]
Old Aug 9, 2002 | 09:18 AM
mlhardy's Avatar
P28 and a Clip
Old Aug 9, 2002 | 09:27 AM
lildrgn2.0's Avatar
New User
Default Re: Battling OBDII (mlhardy)
P28 and a Clip
excuse the impending dumb question but what is
P28?
Old Aug 9, 2002 | 09:29 AM
Spade's Avatar
P28 is a SOHC VTEC ECU......they are cheaper than the DOHC's and can be modified just the same.
Old Aug 9, 2002 | 09:34 AM
lildrgn2.0's Avatar
New User
can i swipe a ECU from a wrecked Prelude Vtec OBDI?
or maybe this?
https://honda-tech.com/zerothread?id=245522
[Modified by Lildrgn, 6:37 PM 8/9/2002]
Old Aug 9, 2002 | 09:45 AM
aklucsarits's Avatar
New User
Why do you want to raise your rev limiter? Unless you have cams and the kind of head flow that will make power above 7600rpm, there is no point in raising the limiter anyway...
You do not want to use a P28 ECU on a H22a, chipped or no chip. The P28 does not support control of the secondary intake manifold butterflies and worse, it does not have support for the knock sensor.
You also do not want to use an P72 ECU that is chipped for a DOHC VTEC B series motor as the ignition and fuel maps will not be good for an H22A. Your best option is a P13 ECU chipped to raise the limiter.
Does your '96 have the peak and hold injectors?
Andrew
Old Aug 9, 2002 | 09:50 AM
Spade's Avatar
Default Re: Battling OBDII (aklucsarits)
Why do you want to raise your rev limiter? Unless you have cams and the kind of head flow that will make power above 7600rpm, there is no point in raising the limiter anyway...Andrew
See his sig.
lildrgn2.0's Avatar
New User
Well. I plan on getting everything that is in my Sig..
This is the package that I plan on getting from JG
Pro Series Heads including full port and polish, comp valve job, new valve stem seals, resurfaced or milled up to .040, hot tanked and cleaned, Titanium retainers, comp valve springs, new valve stem seals,modified valve guides for high lift cams, polished chambers, over size stainless steel intake and exhaust valves
also plan on getting crower cams
and I dont know what my injectors are..
Old Aug 9, 2002 | 10:08 AM
sgT's Avatar
sgT
OBD2 is reprogrammable, however it does cost quite a bit which makes
chipping an older ecu and getting an adapter harness, especially if you want
to get a new program later on in the future it will be much cheaper.
Old Aug 9, 2002 | 10:10 AM
DevinW's Avatar
Check out the http://www.hondata.com site. They might be able to help you out!
Old Aug 9, 2002 | 10:13 AM
sgT's Avatar
sgT
Default Re: Battling OBDII (DevinW)
i just saw that you have a prelude. I wouldnt recommend revving much past the
stock redline. the transmission has a real hard time shifting after that.
Old Aug 9, 2002 | 10:16 AM
New User
See his sig.
My bad. I'm on here at work, and I have all the display sigs, avatars, pictures, etc settings set to "off". So I did not see his sig...
Andrew
Old Aug 9, 2002 | 10:20 AM
New User
Default Re: Battling OBDII (sgT)
I've never heard of that problem before... Can you please elaborate?
Andrew
Old Aug 9, 2002 | 10:41 AM
lildrgn2.0's Avatar
New User
ok... Hondata site says the p72 is the best swap for ecu..
So if I got a hondata stage2b (since I plan on running nitrous in the future)
and found a p72 and got the harness... that should be all i need right?
Old Aug 9, 2002 | 10:52 AM
Spade's Avatar
Correct. Harness and ECU.
crohnman6
Jan 3, 2006 05:36 PM
Turbocoupe97
Aug 15, 2004 11:19 AM
sihatch1.8
Feb 4, 2003 04:13 PM
IdotheSHOCKER
13
Sep 13, 2002 06:50 AM
essex
Jul 8, 2002 12:48 PM
