head bolts must be threaded by hand?
Old Feb 14, 2009 | 01:15 PM
jewjew bean's Avatar
Default head bolts must be threaded by hand?
I'm replacing the head gasket on a older v8 car and when I went to install the head bolts, I noticed that I wasn't able to thread the bolts all the way down by hand. They went down easy with the wrech, however?
I'm worried that I won't be able to get an accurate tq setting if there's drag on the threads. Do you think it's worth it for me to remove the heads and tap the threads or do you think I'll be alright?
thanks
Old Feb 14, 2009 | 01:31 PM
srmofo's Avatar
Default Re: head bolts must be threaded by hand?
they'll be alright, dont worry about it
Old Feb 14, 2009 | 01:47 PM
Scott_Tucker's Avatar
It's definitely going to affect the tension on the bolts but how much depends on how tight the threads are. If it's just a stock rebuild it may not matter but if it's a performance rebuild for peace of mind I would pull the heads back off and chase the threads.
If the threads are going into a water jacket are you using RTV on the threads and if they are not are you using oil on the threads? They should not be dry.
Old Feb 14, 2009 | 01:54 PM
just a stock crapper.....
the head bolts don't go into the water jacket. I followed arp intstrutions and used 30wt oil.
I'm not sure why there tight. I pulled the bolts back out and relubed them only to find them tight again.
On one of the bolts, there were two tiny marks on the threads so I'm guessing the bolt hole threads aren't perfect.
thanks for the replies
Old Feb 14, 2009 | 04:00 PM
Muckman's Avatar
Moderator in Chief
dont re-tap. your more likely to f it up. just torque em to spec and dont over think it.
Old Feb 14, 2009 | 04:57 PM
Did you compare the length of the new bolts to the old bolts? It sounds like they aren't too long, though, the threads are just tight. Are the old bolts tight? You can actually buy a thread chasing tap that won't cut new threads it will just clean up the old ones. It think ARP actually even sells them.
Old Feb 14, 2009 | 05:30 PM
There the same bolts.
I think what happen was when I went to remove he head, water and oil fell into the bolt holes. I blew out the holes but I think rust may have developed inside them.
I went back to the car and rethreaded the bolts on the exhaust side and they went in like butter. So I'm gonna let it sit overnight and hopefully it'll sort itself out
Old Feb 14, 2009 | 07:27 PM
everytime you chase threads with a tap, you remove material - car craft magazine
http://www.carcraft.com/techarticles...ing/index.html
I'm gonna just tq them down tomorrow. I really need to get this done.....
Old Feb 14, 2009 | 08:08 PM
Exactly, that's why you use a thread chasing tap.
Old Feb 14, 2009 | 08:42 PM
srmofo's Avatar
even a thread chase removes some material....if he had said it was still tough with the wrench then I might consider it, but he didnt....dont over think this one, In all honesty your torque wrench probaly isnt that accurate anyway....(what are you using).....just go a little past the spec if your still worried, The old v8s are not as nearly as finicky to torque as newer engines are. hell you could probaly get away without even torqueing it
Old Feb 14, 2009 | 08:56 PM
I honestly didn't know that. I just posted that to brieftly summarize the article, which i thought was pretty good.
I'm shamefully using a cheap china tq wrench. However, I have confidence in it because I did my integra with no problems.
Old Feb 14, 2009 | 09:05 PM
I think you are right, in the end it's not really going to matter. Blowing out any water or oil from the female threads is probably more important than tapping them in this case.
Old Feb 15, 2009 | 05:26 AM
I blew out all bolt holes before the heads went on
White_EG1
Dec 13, 2015 08:12 AM
Littlegreend15
Jun 3, 2005 04:41 PM
Boost2NA
Jul 16, 2003 01:46 AM
civicmatt
May 5, 2003 08:42 PM
smashed4thgen
Oct 20, 2002 07:08 AM
