what do i do with these injector wires?
i have a 90 crx. b18c1 swap. everyhing is hooked up. i have 5 injector wires and im told i dont need an injector resistor box for them. 4 of them are red with black stripe and 1 is yellow with a black stripe. what do i do with them?
solder them all together. the yellow/black wire was the original +12v feed to the res. box. and each of the red/black wires went to the individual injectors. by hooking the +12v yel/blk wire to all 4 red/blk wires, you essentially bypass the box and send the full +12v to each injector. this is assuming you are using the saturated gsr injectors, not obd0 peak/hold injectors.
