Brake upgrade...
Old Aug 9, 2002 | 07:56 AM
RSZero1's Avatar
Default Brake upgrade...
Well, I'm finally moving forward with mods, this weekend I'll be doing a rear disc brake setup on my hx. Any tips? Well I'll keep you posted on how it turns out...next up is my B16 upgrade...and either updating the frontend to 99 si, or getting the CTR grill and lip for my 97. Oh and I may crack open the lights to do a black housing. not sure yet.
Old Aug 9, 2002 | 07:59 AM
Jackson's Avatar
Default Re: Brake upgrade... (RSZero1)
Get the front brakes too. The rears only do like 20% of the braking.
Old Aug 9, 2002 | 08:01 AM
tonyxcom's Avatar
Default Re: Brake upgrade... (Jackson)
Wurd. Intergra or SI front brake upgrade makes a bigger difference and is cheaper.
Old Aug 9, 2002 | 08:02 AM
tonyxcom's Avatar
Default Re: Brake upgrade... (tonyxcom)
I would also save your money on a SI front end swap and put it towards a b18c instead of a b16.
Old Aug 9, 2002 | 08:07 AM
RSZero1's Avatar
I'm actually pretty happy with a B16, don't wanna get too crazy...and for the fronts I have some cross drilled rotors. Are the Si's bigger? Because I saw some company in honda tuning that has a big brake upgrade front and back for about $500. Anyone heard about these? I'll find the ad and let you know who's selling and hopefully who makes...
Old Aug 9, 2002 | 08:12 AM
Jackson's Avatar
99-00 si and gsr brakes are the same size. They are cheap and bolt right on. But then you might as well get the 40/40 prop valve and a 1" master cylinder and stainless steel brake lines.
Old Aug 9, 2002 | 08:26 AM
tonyxcom's Avatar
Spoken like a true ****
FYI, I have the above setup
Old Aug 9, 2002 | 08:34 AM
94CivicSi's Avatar
what did the 40/40 prop valve come out of? GSR?
Old Aug 9, 2002 | 09:09 AM
Jackson's Avatar
Default Re: Brake upgrade... (94CivicSi)
Civic or integra with rear discs. Depending on your car and if it is abs equipped, you will need a gsr/rs/ or 99-00 si. For the 96-00 civics which are not abs equipped, the si prop valve is the easiest way to go.
Nick2018Si
Honda Civic (2016 - Current)
May 3, 2019 04:01 PM
shad295
Honda Civic (2006 - 2015)
16
Nov 4, 2008 03:11 PM
Thanks knightsport!
Jun 14, 2005 01:28 PM
yeegsr
Sep 14, 2004 07:27 PM
