nothing on hatch works
hey guys and gals before i start trying to find the problem myself i figured i'd see if anybody else has any idea what could be the problem
it's a 88 hatch and nothing on my hatch works ( defroster, brake light on wing, and the wiper)
the bulb on the brake light was blown i replaced and still didn't work
the light for the defroster button turns on but the defroster doesn't work
the defroster fuse was blown i replaced it and still didn't work
it sounds like some type of short was wondering if anybody had any ideas before i start working on it
thanks ahead of time
i had a similar problem on my 90 si but only the brake lights weren't staying on,Ended up being my daytime running lights relay.I was told that only the 90-91 have that though?Gl
I was fixing my hatch harness and I noticed that one wire was cut and the other one was about to. The weak spot where I discovered is located by the right side hatch hinge, enclosed in that rubber hose seal thingy. You can check for voltage and continuity using a plug that is located by right tail light (on the inside of the chassis). That will help you eliminate if you problem is hatch harness related. Good luck.
when i got my car, the dome light didn't work, neither did the interior lights in the rear. i have no radio, just wires haning out. i tried replacing the fuse, but it kept blowing every time i'd hit a bump, or close the door ect... one day i put a fuse in and the light stayed on even when i closed the door. then i decided to push the wires in the head unit hole. long story short..er.... check for some loose wires under the dash somewhere, fuse panel, something touching...
90efSI
Dec 13, 2005 12:26 PM
drew2
Jan 20, 2004 12:03 PM
