light in the hatch
Old Jul 24, 2002 | 04:58 AM
2000GSR's Avatar
Default light in the hatch
That light in the hatch mysteriously stopped working one day, When I pump my system it tends to vibrate the light/housing and it falls out of its hole dangling by the wires. The bulb is not blown(i even tried a new bulb), the connection seems secure, i flick the switch and still doesn't work. Does anyone know what the problem may be? Thanks
Old Jul 24, 2002 | 06:08 AM
WOTTEG's Avatar
Default Re: light in the hatch (2000GSR)
Make sure the switch on the light is "On"
Use a multimeter:
check for 12V between the two wires in the light's harness.
If this fails:
Check for continuity between the Positive lead in the harness, and a good ground on the body.
If this Passes:
Check to make sure that your "Hatch Open" light comes on when you start the car and leave that hatch open.
If this passes:
You have a broken ground wire from the light's harness.
The light is ground-actuated, so the trunk-open switch uses the light's ground wire to turn it on.
[Modified by WOTTEG, 9:09 AM 7/24/2002]
Old Jul 24, 2002 | 06:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: light in the hatch (WOTTEG)
dang mine has the exact same problem, it really sucks when opening the hatch at night I'll have to check that stuff out.
OH_1fstgsr
Dec 29, 2007 02:48 PM
LDCintegra
Feb 16, 2006 04:12 PM
TypeRod
Nov 16, 2005 05:12 PM
crxss outhe eyes
Mar 16, 2005 08:46 PM
98R-1144
Audio / Security / Video
Jul 31, 2002 01:12 PM
