My motor finally got started yesterday!
Old Feb 13, 2009 | 09:47 PM
meanshyguy's Avatar
Default My motor finally got started yesterday!
I have a couple of questions before I break something in the engine.
The car idles for a couple of seconds and then drops, I'm not sure if it's a timing problem but I have crower stage 2 cams and I don't know if I should retard the cam gears a couple of degrees because of them. The compression is about 11:5.1 I'm using the obd1 dizzy, since my build is an H23vtec and Im using a P28 ecu, H22 mapped just for now while I break in the motor. What else should I check?
I also have a question about the aftermarket oil cooler:
Will there be any oil pressure issues by using this oil cooler, I'm removing the stock one, or is there anything that I should worry about?
Old Feb 14, 2009 | 06:59 PM
meanshyguy's Avatar
Default Re: My motor finally got started yesterday!
So does anybody have any suggestions or answers to my questions?
norcalB18
Nov 17, 2009 04:38 AM
4LugR
Nov 13, 2006 01:59 PM
Don Johnson
Oct 5, 2004 10:47 PM
