How Difficult to Install Brake Lines?
Old Aug 9, 2002 | 07:42 AM
Flux's Avatar
Default How Difficult to Install Brake Lines?
I'm starting to really enjoy this working on your own car thing.
How difficult is it to install a set of SS brake lines? Is there a guide or how-to anywhere online?
Old Aug 9, 2002 | 07:46 AM
reefer_bob's Avatar
Default Re: How Difficult to Install Brake Lines? (Flux)
It's really not that difficult. It's a messy job, and you should really have a set of Flare nut wrenches, but still not all that dificult. I'm sure there is a how-to, but your best bet is a Helms manual...
I guess it all depends on how comfortable you are doing work, cause now rather than just adding a CAI or something, your working on the MOST IMPORTANT system on your car. If you mess up this install, there could be dire concequences.
Just some food for thought.
Old Aug 9, 2002 | 07:47 AM
Flux's Avatar
Default Re: How Difficult to Install Brake Lines? (reefer_bob)
...your working on the MOST IMPORTANT system on your car. If you mess up this install, there could be dire concequences.
Believe me, I have thought about that...
Old Aug 9, 2002 | 07:49 AM
nerdish's Avatar
Like replacing the old lines with SS ones and whatnot? It's not too bad.. especially with a manual, you'll be fine. Just make sure you get the air out of the lines. That took us a while..
Old Aug 9, 2002 | 07:51 AM
VTECPWR's Avatar
Default Re: How Difficult to Install Brake Lines? (nerdish)
It was easy. The only problem I had was one of the nuts was frozen and we stripped it some. Just ended up cutting the old line as that bracket was not used with the new lines
Old Aug 9, 2002 | 07:56 AM
nerdish's Avatar
Default Re: How Difficult to Install Brake Lines? (VTECPWR)
We couldn't get the left-front bolt off the fender well... we had to heat that ****** up with a torch.
Old Aug 9, 2002 | 08:08 AM
reefer_bob's Avatar
I've never had a problem like that... The last car I did was a '93. Just put some penetrating oil on the nuts, get yourself the flarenut wrenches, and you'll be good to go.
Proper bleeding is essential. This is a great time to flush your brake fluid with some good stuff. Get something that's a different color, so you know when you've flushed all the lines.
Old Aug 9, 2002 | 08:13 AM
oldskool_rex's Avatar
it isn't bad.....here are some brake line/fluid rules of thumb...
:don't mix fluid grade (I don't like to mix fluid brands either)
:water instantly neutralizes brake fluid. don't get water anywhere near fluid to be used, and if fluid spills, water will get it up the best.
:keep it away from you paint if possible. if it spills on your fender, have a wet rag ready.
:never use old fluid, even if it is unused. moisture in the air will **** it up. fresh bottle is key
:bleed brakes according to manual, but I like to start from the wheel farthest from the master cylinder and go closer.
:make sure you have plenty of pressure before driving the car (means, pump the pedal and check for leaks)
:2 people are better than one during bleeding.
oh, and do yourself a favor and make sure the lines don't rub on anything.
Old Aug 9, 2002 | 08:36 AM
fowler!'s Avatar
Default Re: How Difficult to Install Brake Lines? (oldskool_rex)
That happened to me. I started wondering where my brakes went and why that line of fluid keeps following my car...
Zip ties fixed that.
Old Aug 9, 2002 | 09:44 AM
Default Re: How Difficult to Install Brake Lines? (fowler)
you hack
Old Aug 9, 2002 | 09:46 AM
fowler!'s Avatar
Dude, Tony did that side. Mine held up find
Old Aug 9, 2002 | 09:53 AM
BudMan's Avatar
be careful - check to see how tight to tighten the banjo bolts....if your kit comes with new ones, don't over-tighten!
You won't be smiling when the bolt head goes "pop"
Overall, one of the easiest "how-to's" that most people won't try, but I think is well worth the $$.
Whatislove
Honda Civic (2001 - 2005)
May 19, 2009 05:41 AM
N24RE
21
May 13, 2004 03:02 PM
youngvedder
Mar 17, 2004 10:31 AM
lePetitePrince
Nov 6, 2002 02:33 PM
Regular Series
Aug 16, 2002 08:59 PM
