Does an h22 obd1 swap require a resistor box?
Old Feb 13, 2009 | 06:25 PM
raidacaipo's Avatar
Default Does an h22 obd1 swap require a resistor box?
Does an h22a obd1 engine swap into a civic require a resistor box if I'm using anything other than a p13 ecu?? I heard that you don't need the resistor box if your not running a prelude ecu is this right??
Old Feb 13, 2009 | 09:12 PM
raidacaipo's Avatar
Default Re: Does an h22 obd1 swap require a resistor box?
bump
Old Feb 13, 2009 | 09:14 PM
JDM JEFFREY's Avatar
thats right
Old Feb 13, 2009 | 10:25 PM
raidacaipo's Avatar
Originally Posted by JDM JEFFREY
thats right
so is it okay to use the stock obd1 fuel injectors? since they are peak and hold and are they low impedance or high? what cc are the stock h22 injectors?
Old Feb 14, 2009 | 12:33 PM
DSRxCandyh2bEG's Avatar
they are low impedance injectors. you need a resistor box regardless of ECU. The injectors have low resistance (peak and hold), hence the need for a resistor box. High impedance injectors have high resistance, no need for a resistor box.
The injectors are something like 340cc's or something. I would change them out to obd2 prelude injectors (280cc) and not run the resistor box since they are high impedance (saturated)...
to sum it up, if you use the obd1 injectors, you need a resistor box regardless of ecu...
Old Feb 14, 2009 | 12:46 PM
raidacaipo's Avatar
gotcha.. thanks very much.. what size injectors do you recommend for an h2b swap with bolt ons and a tune??
Old Feb 14, 2009 | 09:22 PM
dohcem1's Avatar
DSRxCandyh2bEG really knows his things. He taught me couple things I suggest get RC 370 or PTE 440. I just got the PTE 440s with chipped uberdata basemap. Of course it's calibrated to 440 cc ... etc
Old Feb 14, 2009 | 09:26 PM
raidacaipo's Avatar
alright thanks for the advices
Old Feb 14, 2009 | 09:47 PM
raidacaipo's Avatar
In that case I have a JDM 96 h22a engine. Does that mean its an obd2a engine since its 96? but at the same time the fuel injector plugs are obd1 style plugs and not obd2. So do I have obd2 fuel injectors being that the engine is a 96 h22a???????
Old Feb 15, 2009 | 01:29 AM
nope, its a motor made in early 96 from a late 95 prelude.... same as mine
it says 96 on the head but its all obd1...
Old Feb 15, 2009 | 01:33 AM
honestly, RC 370's should suffice, but there is nothing wrong with some 440's, as long as you get tuned...
RicanRacer253
Oct 3, 2019 10:21 PM
raidacaipo
16
Feb 15, 2009 12:26 AM
spraymysol
Dec 8, 2008 02:48 PM
immorality
May 24, 2008 03:46 PM
lowtegsr
Jan 14, 2008 01:25 PM
