Oil capacity
Old Feb 13, 2009 | 05:31 PM
Horatus's Avatar
Default Oil capacity
I did a search and didn’t find anything; how much oil are we suppose to run in our H2B’s? I know the Mfg req. but mine reads like a quart over full at 3.5 quarts (due to how the engine sites). Thanks for the help!
Sorry if this has been discussed already : /
Old Feb 13, 2009 | 07:12 PM
philafelman's Avatar
Default Re: Oil capacity
damn, my h22 takes i think 5.9qts. i cant imagine an h2b changing the h22's oil capacity.
Old Feb 14, 2009 | 03:19 PM
Horatus's Avatar
Your right it doesn’t change the capacity, but since the engine sits slightly forward and the dip stick does not read accurately, I am not sure if I would damage anything with it sitting like that with the dip stick reading way over..? : /
Old Feb 14, 2009 | 03:59 PM
DSRxCandyh2bEG's Avatar
It wont damage anything but you might want to put a oil drain bolt in the front of the pan instead of the back. the oil wont drain completely otherwise.
Mark the dipstick at full and that will be your new fill line...
Old Feb 14, 2009 | 11:16 PM
sicc22's Avatar
i add a extra 1-2 quarts over. but the best thing is a oil pressure gauge i remember when i changed my oil the first time. i got a lot of the oil out by jacking up the front of the car. anyways i filled it back up and i reached my "new" oil file line. but when i ran the car for a test drive oil pressure would drop in vtec. scary. went and got a few more quarts till it was a little over the full line and it was fine after that.
Old Feb 16, 2009 | 12:52 PM
Horatus's Avatar
Cool thanks for the feed back.
Old Feb 16, 2009 | 04:42 PM
sauceja's Avatar
Basically.
Another thing is if you just got the motor back together after a KS BS install then you know there is no oil in your motor so you can add the oil to the line, and then add the extra oil to develop a new line and know exactly how much was in there. Because you won't be able to get all the oil out on future oil changes unless you get a vacuum pump or figure something else out.
Old Feb 17, 2009 | 07:24 AM
sicc22's Avatar
oh yea forgot to mention i do have the KS balence shaft kit. but yea thats exactly what i did the first time to set my fill level. the KS kit is sex to bad its covered by my Timing belt cover.
Old Feb 17, 2009 | 04:15 PM
sauceja's Avatar
Who needs covers when you got bling. Thats like having a badass pinky ring and wearing a glove all the time.
Old Feb 23, 2009 | 06:17 AM
sicc22's Avatar
the pinky ring (i would rather have the glove to protect the hand that wears the ring)
Safety_Driver
10
Jan 16, 2012 12:45 PM
pjr710
Jun 3, 2008 03:45 AM
bopbop93030
May 13, 2008 04:30 PM
CRXstress
Sep 27, 2004 10:01 PM
IVANITR
Nov 30, 2001 01:05 AM
