Can someone with a multimeter do me a favor?
Old Feb 13, 2009 | 11:04 AM
97civic07gsxr's Avatar
Default Can someone with a multimeter do me a favor?
Can someone run and check how many volts the fuel injectors should be getting, mine are getting around 9v and i'm not sure if it should be 12 or what
Old Feb 13, 2009 | 01:53 PM
joelmatt89's Avatar
Default Re: Can someone with a multimeter do me a favor?
it should be 12
Old Feb 13, 2009 | 01:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
yellow and black should be 12v
what do you have at the battery?
Old Feb 13, 2009 | 02:21 PM
is it constantly 12v? bc my yellow/black wire is only getting 9v. My battery is 12. something. could be the cause of my car not being able to start?
Old Feb 13, 2009 | 02:24 PM
ekb16's Avatar
probably got some resistance somewhere
Old Feb 13, 2009 | 03:01 PM
would that blow a fuse? prevent startup?
Old Feb 13, 2009 | 04:54 PM
Mr. Badwrench
do you have a resistor box wired in wrong? did you change anything?
what problem are you having?
Old Feb 13, 2009 | 05:37 PM
well i just went and checked and it's at 12 again (still not starting though) but yesterday it was at 9 V. i dunno i give up i'm about to part this thing out. I had a short to ground in my wiring harness (on that yellow/black wire) and it wouldn't start, kept blowing my FI fuse, but i found it and fixed it and it started up onetime not it isn't starting anymore. It's getting some spark (I don't know if it's enough or not) and it's getting fuel. I can spray ether in the throttle body and it still doesn't even act like it wants to turn over, just steadily cranks and cranks
Karado58
Audio / Security / Video
Nov 17, 2009 01:25 PM
ShadowBar
Jan 26, 2009 05:32 AM
Jonathan_ED3
Sep 5, 2002 10:12 AM
grngsr01
Jun 2, 2002 01:25 PM
