gsr air fuel ratio
make sure you check it when the car is fully warmed up, when the coolant is cold the ECU follows enrichment tables and add's extra fuel until the coolant reaches a certain point, make sure the heater and ac is off too. Best bet is to put a fresh set of spark plugs in and learn how to read them, or buy a used wideband and be done with it. From what I have learned the tailpipe sniffer will read a point leaner than close to the head where it should be, so 12.0 is pretty pig rich for a stock car, should be in the 15's.
Hockey27925
23
Aug 21, 2005 06:20 AM
