Valve Adjustment needed?
Old Aug 9, 2002 | 06:31 AM
Ri5e's Avatar
Default Valve Adjustment needed?
I just finished putting back my motor. When at TDC, the #1 piston, the 4 rocker arms should all have the "same looseness" to them correct? Because 3 of them have the same looseness feel and one of them feels kinda "tight".
What's the correct way to do a valve adjustment?
Old Aug 9, 2002 | 06:40 AM
SlowTeg's Avatar
Default Re: Valve Adjustment needed? (BG Boost)
I'm not sure exactly what you mean by each of them having the same "looseness." It's definetly a good idea to do a valve adjustment before you throw the valve cover on.
To do a valve adjustment, simply set the cyl you're doing to tdc, and then use a feeler gauge and adjust the clearance.
-Mike
Old Aug 9, 2002 | 07:48 AM
Dutchie's Avatar
They should all have the same "looseness" when the cylinder you are measuring is at tdc. If you measure them with #1 at tdc, one or more cylinders will be off. You have to adjust each cylinder at tdc. www.c-speedracing.com Under the how-to section.
fwdupree
Jun 1, 2018 12:13 PM
NA JDM GSR
Oct 17, 2006 10:50 PM
$$broke_db8
Jul 5, 2006 05:09 AM
