Brake Lights Dont work!!!!
Whats up honda tech, ok I have a 91 EF and my brake lights don't work. I check the fuses and changed it and they worked again. Put then the fuse popped and i kept replacing it and right away the fused popped again and it did that multiple times. I don't know what is wrong can someone help me please. thanks a lot!!
You should also check the light sockets in the rear. Sometimes a badly rusted socket can cause a fuse to continue to blow, or water in the light can do the same thing.
You might also consider checking the brake lamp switch at the brake pedal. Sometimes these switches stop working (short out) and it will cause the same problem you are talking about. just an idea...good luck!
Chee_dog
29
Aug 15, 2009 03:17 PM
b16a2pwr
Feb 14, 2004 02:28 PM
