rear lower control arms question
Old Feb 13, 2009 | 08:00 AM
jriley60's Avatar
Default rear lower control arms question
do i have to use si control arms to install and si sway bar or are there other options? I know i can get aftermarket. can i use like da lca's or what. i've tried looking but can't find a definet answer anywhere
Old Feb 13, 2009 | 07:54 PM
ninty1civic's Avatar
Default Re: rear lower control arms question
no u can use dx hf std ex lx rer lcas
Old Feb 13, 2009 | 08:01 PM
ed8_dx's Avatar
Dx lcas don't have the threaded holes 4 the end links so no u can't use them
Old Feb 14, 2009 | 01:55 AM
NlCK B's Avatar
my base model 89 dx came with the threads you just have to make sure what ever arms you use that they have those threads
you can use intergra da or dc2 arms *** long as they have those threads you will have a wider track thought i forgot how much wider
Old Feb 14, 2009 | 05:23 AM
88Hatchy's Avatar
DA and DC LCAs are the same length.
Old Feb 14, 2009 | 08:09 AM
EJ8CIVIC's Avatar
i got aQcan i use 96+ civic lca?
Old Feb 14, 2009 | 11:44 AM
Crx Jimmy's Avatar
no only eg and dc arms will work
Old Feb 14, 2009 | 03:42 PM
sgallagher's Avatar
So by installing Da, etc. arms and increasing the track how will that effect suspension geometry. Providing a longer/adjustable upper arm is installed and an alignment is performed.
Old Feb 14, 2009 | 04:09 PM
88Hatchy's Avatar
as long as you use LCAs from an Integra or 88-95 civic, your track width will not increase
Old Feb 14, 2009 | 04:23 PM
Tyson's Avatar
dont use a DA rear lower control arm. the shock bushing is in a different location.
DC or EG is fine to use on a EF.
you will need the ones with the swaybar holes tho.
new control arms from honda are less than $150/pr.
Old Feb 14, 2009 | 04:30 PM
sgallagher's Avatar
Are the EG/DC arms any longer?
Old Feb 14, 2009 | 04:31 PM
sgallagher's Avatar
Gotcha.
Old Feb 14, 2009 | 06:06 PM
hondacivicwagon.com's Avatar
I need some colored arms for the wagon.
Old Feb 14, 2009 | 08:05 PM
barely4dr's Avatar
i'de recommend:
skunk2
PIC
Function7
DA6righthand
Suspension & Brakes
Apr 17, 2007 08:16 AM
madmanmaigret
May 1, 2006 03:49 PM
supracrx
Mar 29, 2006 09:23 PM
mattjohnston
Sep 9, 2002 09:20 PM
