now for cruise control
Old Feb 13, 2009 | 06:40 AM
coolharry's Avatar
Default now for cruise control
i've got a long drive to and from work. 93 si, cruise control usually works. sometimes the light comes on and it wont hold speed. when it does work, the light comes on, but it then takes anywhere from 2-10 seconds to engage.
anyone know of a way to fix this? or do i just have to suck it up?
Old Feb 13, 2009 | 08:50 AM
98vtec's Avatar
moderator emeritus
Default Re: now for cruise control
make sure you do not have any leaks.
Old Feb 13, 2009 | 09:02 AM
95greenlude's Avatar
there is also a nut of the CC unit (the big cone looking thing that controls the vacuum.) I would make sure that it is adjusted properly
Old Feb 13, 2009 | 09:59 AM
coolharry's Avatar
how would i go about checking for leaks? i've never worked on CC before, this is the first time i actually have it.
Old Feb 13, 2009 | 01:11 PM
gstrudler's Avatar
older cc seem to have a little lag when engaging, i think. i had a '97 del sol and it took a couple seconds for the cc to engage after setting it, and then it would have to catch up; it was kind of lame.
Old Feb 14, 2009 | 11:23 AM
coolharry's Avatar
yeah its the lag that i really wanted to fix, i hate it. i think the cold is to blame for it not working all together. theres gotta be a way to fix it......
Old Feb 14, 2009 | 11:54 AM
Crash_Control's Avatar
My cruise froze up this winter when it got warmer it worked again.
I am gonna put a moisture trap/catch can in so it might not freeze up net year.
Old Feb 15, 2009 | 10:34 PM
gstrudler's Avatar
i have no idea if they're compatible, but you could see if there's a way to swap in a cc from a 5th gen... anybody tried this before?
Old Aug 1, 2009 | 08:50 AM
coolharry's Avatar
i feel like bringing this back up.
anyone have anything to add?
Old Aug 1, 2009 | 04:34 PM
HdeucedeuceA's Avatar
When I still had mine, it engauged almost instently.
Old Aug 2, 2009 | 05:02 AM
street_ride14's Avatar
What have you tried ? Did you check/fix any leaks ? Most people just remove the CruiseControl unit and lines all together to avoid problems / clean up engine bay. Your best bet would be to diagnose the problem using a Helms shop manual as your guide.
Old Aug 2, 2009 | 11:01 AM
coolharry's Avatar
all i have is the pdf version of helms, anyone know the page numbers for cruise control?
1400 pages without an index is no fun.
zmss56
Honda Civic (2001 - 2005)
Dec 13, 2012 06:32 PM
delsolguy32
Jun 6, 2011 09:03 PM
Tranceaddict87
May 24, 2008 07:46 AM
HuskerHybrid
Jan 16, 2003 04:58 PM
