Exhaust gone
My exhaust system is rusted beyond repair, including the cat. I was wondering if it would be much more money to get an aftermarket high flow cat and header than it would to just replace the original cat and manifold. Can anyone recommend one that won't break the bank? I don't care about looks, I just want one that will help with fuel economy and maybe an extra hp or three.
well if your looking for just fuel economy then just go to a muffler shop and get them to put one on for you. if your lucky, no more then 300(cause stock cats are expensive).
Need more info.
What engine?
Mileage?
Car purpose?
A header won't do much if the engine isn't built. The factory exhaust manifold will outlast the car. Just because it is ugly and rusty, doesn't mean it isn't functioning well. The rest of the exhaust is understandable. Buy a cheap high flow cat, a decent muffler and have a local shop bend and weld up the pipe. It should be economical and flow better than stock.
What engine?
Mileage?
Car purpose?
Need more info.
What engine?
Mileage?
Car purpose?
What engine?
Mileage?
Car purpose?
unless your manifold is cracked(have seen it happen) no you don't need too. cat and muffler well do for a commuter.
Thanks, I just got nabbed for an inspection ticket by a cop tonight, and my exhaust sounds like a lawnmower on steriods. I know it has holes all up and down, its the original 97 exhaust. I'll look for a cheap cat back kit and a high flow cat and see how it goes.
I got a cat back to the can already on the car done for like 180 at a local shop.
The DX's exhaust manifold goes directly into the cat which means to use a high flow you have to swap the manifold out and then it goes to a full custom set up unless you do an EX swap over in which you replace the exhaust manifold to the muffler with that off of an EX. I did this with my buddies LX (uses the same D16Y7 motor) with an ebay kit of his choosing and then added an ex cat later on.
or u could buy a cheap ebay exhaust kit that includes headers, test pipe (not DOT legal), and catback exhaust. i ordered one of ebay for $180 shipped and ill change the fart can later when i finish doing other things. i bought for the same reason too tho, exhaust has holes everywhere and the cat is rattling like the ceramic fell apart inside...
link to exact thing i bought: http://cgi.ebay.com/ebaymotors/_Raci...1%7C240%3A1318
punoy69
Nov 11, 2006 07:06 PM
