1996 integra gsr OBDII engine check light p1381 HELP!
Old Feb 12, 2009 | 04:16 PM
tduzzle's Avatar
Default 1996 integra gsr OBDII engine check light p1381 HELP!
hey i really need help. i have a acura integra 1996 gsr the other day the check engine light came on i reset it and came back on it read p1381 Cylinder Position Sensor Intermittant Inturruption... i had the sensors replace and it still comes on? my friend said it might be the 18 teeth that clamp onto the cams or whatever and he said it might be missing 1 tooth is that true? any suggestions?!?! PLEASE HELP! what do i do ?
Old Feb 12, 2009 | 04:37 PM
ruffrhyder's Avatar
Default Re: 1996 integra gsr OBDII engine check light p1381 HELP!
Possible short on the harness that leads to the crankshaft position sensor. Somehow my alternator belt cut through mine and gave me the same code. After I repaired the wiring and deleted the code, it never came back. This is on my 97 OBD2 GSR
Old Feb 12, 2009 | 06:24 PM
racebum's Avatar
could be and or you could have a ton of crap built up if you have any cracks in your plastic cover to allow junk to find it's way in. worst case the sensor needs to be replaced.
Old Feb 15, 2009 | 12:30 AM
tduzzle's Avatar
replace sensor prolly thinking it is the rotor any suggestions where to find a good cheap new distributor
Old May 13, 2009 | 02:05 AM
tduzzle's Avatar
fix the problem icm
jonesEK
Feb 1, 2011 06:30 PM
h22a4 swap
Jul 9, 2009 08:38 PM
Redgy
Feb 26, 2007 10:37 AM
Web_Head
Sep 29, 2004 08:25 PM
henrik
Sep 3, 2003 12:24 PM
