Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
cam gear question
Old Feb 12, 2009 | 03:23 PM
Igaly's Avatar
Default cam gear question
i got a simple question I did my freinds cam gear on his 01 civic..... but I need somebody to explain to me what is the diffrence between the negative and positive side, right now I set it at 0 degrees does anybody know at what degree should I set it at
Old Feb 12, 2009 | 03:48 PM
toyomatt84's Avatar
Sanji
Default Re: cam gear question
You should do some research on engine timing.
PS. I hope your friend isn't expecting any performance increases, because there won't be any.
Old Feb 12, 2009 | 06:57 PM
Igaly's Avatar
but can somebody explain to me what are those + and - numbers are for on the cam
Old Feb 12, 2009 | 07:20 PM
toyomatt84's Avatar
Sanji
Wow...
... that pretty much sums it up. Cam/Valve timing are all that the aftermarket Cam gear will handle. +/- refer to how advanced/retarded the timing is compared to the crankshaft.
http://www.circletrack.com/enginetec...ing/index.html
http://www.compcams.com/Technical/TimingTutorial/
http://www.type2.com/library/electrip/timex.htm
Old Feb 12, 2009 | 07:44 PM
scspeed's Avatar
Its to increase or decrease your timing by degrees, that is what the numbers are for+ and -...and to get them where they should be you would need to tune the car with most likely a dyno tune for the nest results. Or if you could even find sombody elses specs you mite be able to go off of theres if they had the same EXACT setup.
Old Feb 13, 2009 | 08:59 AM
unevolved's Avatar
Oh man, you shouldn't have said that.
Be very, very careful with that timing gear. You're most likely going to mess up your motor playing with it.
Old Feb 13, 2009 | 03:20 PM
skipbarber's Avatar
it'll be really hard to get any power out of a cam gear on a sohc since both intake and exhaust lobes are on the same shaft.
Old Feb 13, 2009 | 08:33 PM
Igaly's Avatar
then i guess this guy just waisted his money o well
Old Feb 14, 2009 | 05:02 AM
kenbo21's Avatar
I really dont think you should be doing a cam gear when you clearly have no idea what you are doing. If you set the timing 1 degree off..say goodbye to the engine!!!! goodluck ur going to need it...
Old Feb 14, 2009 | 07:54 AM
Igaly's Avatar
kenbo then since u know more than me then tell me at what degrees I should set it at??? cause since it's a crapy single of course i'ma get lost....... so tell me smart guy
Old Feb 14, 2009 | 08:58 AM
unevolved's Avatar
You shouldn't set it at all, since it's a single-overhead cam and you clearly don't know what you're doing.
Old Feb 15, 2009 | 06:40 AM
scspeed's Avatar
You can just "set it" at some degree and have it run right, you would have to have some kind of a basemap or return to run correct on depending on the degrees you set it at.
89ED
18
Jun 22, 2018 03:38 AM
Ef4doorwagon
13
May 17, 2014 06:09 PM
jdm27ef
May 29, 2009 02:52 PM
sk8shorty012
Mar 13, 2006 11:26 AM
