stripped block
Old Feb 12, 2009 | 03:22 PM
biggoofy's Avatar
Default stripped block
i drive a 94 integra ls and the drivers side holes in the block where the motor mount attachs are stripped does anybody have experience with this i need help do i need to pull the motor or can i just use an engine hoist to hold it and retap the holes
Old Feb 12, 2009 | 03:27 PM
fatboy1185's Avatar
Big Cat
Default Re: stripped block
Just pull it out enough to retap.
Old Feb 12, 2009 | 04:11 PM
non-VTEC's Avatar
drill, tap, heli-coil insert is the only way to fix that.
if you have access to a angle drill and really short drill bit then you can do it while the engine is still in the car.
i ended up doing that to my previous motor. it worked out well. you need to be really paitent and give yourself 3-4 hours to do it right.
Old Feb 12, 2009 | 04:47 PM
biggoofy's Avatar
where can i find the kit to do this and is there a link to a diy ?
Old Feb 12, 2009 | 04:55 PM
Boosted_B_Series's Avatar
the heli coils for that size bolt are a little hard to find..
I think the bolt is 10x1.25
Old Feb 12, 2009 | 05:39 PM
biggoofy's Avatar
will they hold 350 ft lbs of torque
Old Feb 12, 2009 | 05:50 PM
non-VTEC's Avatar
if you are thinking the engine power has anything to do with the fact your bolts broke or stripped out....think again.
someone overtightened them. period. "350ft/lbs of torque" means nothing.
have someone with the proper tools and equipment repair it.....or replaced the engine block.
Old Feb 12, 2009 | 07:00 PM
Either helicoil it or drill and tap it to use a larger size bolt.
Old Feb 12, 2009 | 08:14 PM
hayabusa160's Avatar
retap or timeserts
Old Feb 12, 2009 | 08:19 PM
biggoofy's Avatar
ok so i can retap with a bigger size and be good?
Old Feb 12, 2009 | 09:05 PM
yes.
Old Feb 13, 2009 | 03:16 AM
non-VTEC's Avatar
if you drill and tap the holes larger you will also have to drill out the holes on the mount bracket.
Old Feb 13, 2009 | 06:21 AM
biggoofy's Avatar
which would be stronger to retap and go bigger or retap and helicoil
Old Feb 13, 2009 | 02:14 PM
philafelman's Avatar
what the hell are you tightening, a roller coaster? i dont think anything on an engine should be torqued anywhere near 350ft/lbs. i would go with helicoils and keep stock bolt size.
Old Feb 13, 2009 | 06:26 PM
biggoofy's Avatar
i ment the motor is putting out 350 ft lbs of torque and was wonder if it would hold the rotational force of the motor
Old Feb 13, 2009 | 06:41 PM
rip94delsol's Avatar
retap and timesert or helicoil. alot of ppl do it with their blocks. Hell I had it done and im looking for 800+hp.
Old Feb 13, 2009 | 06:50 PM
biggoofy's Avatar
ok that was my concern thx i will be doing this tomorrow so i can finish tuning my ****
roscomojo
Honda Civic (2001 - 2005)
Apr 17, 2017 07:36 PM
ProjectEvilEj2
Dec 25, 2012 09:57 AM
Homotor
Apr 20, 2007 02:11 PM
mountaindewguy
Jan 31, 2006 10:11 PM
