Fuel Pressure Adaptor Nut
Old Feb 12, 2009 | 02:29 PM
jbparrothd21's Avatar
Icon6 Fuel Pressure Adaptor Nut
Hey guys, I am trying to trouble-shoot some starting issues with my 99-SH and I am trying to isolate the issue (compression numbers, spark, fuel pressure) The question I have is how are you guys checking the fuel pressure. I have a fuel pressure tester gauge and when I loosen the banjo bolt on the rail there is definately fluid; but since this is an intermitant problem I wanted to get some specific numbers...how do you connect the gauge to the rail. The gauge I have is a schrader type tester kit.
More specifically, what gauge are you using, and where did you get that fuel pressure adapter nut that it talks about in the service manual?
(Searching gave me nothing)
Old Feb 12, 2009 | 08:12 PM
Default Re: Fuel Pressure Adaptor Nut
Forgot to add, it is on the stock rail, not an aftermarket part.
Old Feb 13, 2009 | 01:56 PM
Anyone know?
Old Feb 15, 2009 | 12:30 PM
Well I guess that is a big swing and a miss from the other members...any way after some online digging, if anyone else finds this thread looking for an adaptor that the Honda dealership cannot track down....Actron makes one that converts the banjo bolt fitting to a schrader fitting which works with all the basic gauges you can get from sears or autozone. Hope that helps.
Veggie Man
Oct 25, 2012 05:53 PM
B00STED Si
Jun 7, 2005 09:11 AM
twincamrex
Aug 27, 2002 12:55 PM
