wiring problems galore... *sigh*
Nice huh? Ya I know...
This is the condition that the wiring harness and jumper was in when i got my crx chassis in.
I hooked everything up and tried to fire the car, it cranks but wont fire. The motor ran perfectly when it was yanked from the 01 GSR.
FACTS:
- 2001 OBD2 B18C1 Swap
- Original CRX DX engine harness was converted to OBD1 B series
- The ECU i'm using is a chipped P06 running a P72 basemap for the record.
1) I need to know if the harness pins for the ecu were different between 88-89-90-91 I have a 90 DX and firstoff, a pinout for the ecu plugs would be a great starting point to getting this shithole of a wiring job worked out.
2) would you guys trust that jumper or should i remove it altogether and do the wiring myself?
3) The distributor is OBD2 it came with the 01 GSR swap that is currently in the car. I cut the dizzy plugs off of a OBD1 distributor and soldered them on color-matched to the wires on the OBD2 dizzy. Could this be causing part of the problem or is the wiring correct?
does anyone have a wiring diagram for both an obd1 dizzy and an obd2 dizzy?
more questions to come as you dear friends of mine help me unravel this mystery that is...
"THE WIRING NEST!!!!"
i gotta get this thing running as soon as possible.
The headlights work, open door buzzers work. turn signals dont work. HVAC controls light up but dont kick on.
^ all these things have nothin to do with the swap i recomend you check fuses first.
watch the wiring for the obd2a and obd2b dizzy plugs im sure they are different
as for the enging not turning over make sure the starter large wire has 12 volts and that the starter wire (small) has 12volts while cranking.
that a start for you any way check back with a update
how can you tell the difference between a obd2a and a obd2b dizzy?
all i did on the plugs was match the wire colors up with each other. each wire on the obd1 plugs had a match on the obd2 dizzy.
also, i thought both starter wires went on the starter terminal?
the battery cable that i have in the car is from an eg. The one end goes to the fusebox, the second terminal goes to positive battery and the 3rd part goes to the starter, correct?
man im confused as ****, i had the electrical side of things.
dont be worried about the dizzy yet the starter has 2 treminals a large one from the fuse box and a small one from the drivers side wiring bundle its a black with with wire with a spade treminal make sure this is correct and try to fire it or at least make it turn over.
when you pin the dizzy plugs you need to hold them both side by side with both release plugs at top top position and move the pins from one to the other EX: top left to top left, second from left to second from left etc
hope this helps
hope this helps
This is what I used to do my obd0 to obd1 for the ecu
OBD-0 --> OBD-1 HARNESS CONNECTIONS: PROOF-READ BY TURBOGIXXER
A01 - INJ #1 --> A01 - INJ #1
A02 - PG1 --> A23 - PG1
A03 - INJ #2 --> A03 - INJ #2
A04 - PG2 --> A24 - PG2
A05 - INJ #3 --> A05 - INJ #3
A06 - PCS --> A20 - PCS
A07 - INJ #4 --> A02 - INJ #4
A08 - LOCKSOL --> XXXXXXXXXXX
A09 - NOTUSED--> XXXXXXXXXXXX
A10 - EGR CSV--> A11
A11 - IACV --> A09 - IACV
A12 - FLR1 --> A07 - FLR1
A13 - IGP1 --> A25 - IGP1
A14 - FLR2 --> A08 - FLR2
A15 - IGP2 --> B01 - IGP2
A16 - GRD --> A26 - LG1
A17 - NOTUSED--> XXXXXXXXXXXX
A18 - GRD --> B02 - LG2
B01 - VBP --> D01 - VBU
B02 - NOTUSED--> XXXXXXXXXXXX
B03 - ACC --> A15 - ACC
B04 - FANC --> A12 - FANC
B05 - ALT --> A16 - ALT
B06 - MIL --> A13 - MIL
B07 - NOTUSED--> XXXXXXXXXXXX
B08 - ACS --> B05 - ACS
B09 - NOTUSED--> XXXXXXXXXXXX
B10 - CYP P --> B11 - CYP P
B11 - FUSEBOX--> xxxxxxxxxxxx
B12 - CYP M --> B12 - CYP M
B13 - FUSEBOX--> B09 - STARTER
B14 - ALT --> D09 - ALT
B15 - Igniti --> A21 - ICM
B16 - VSS --> B10 - VSS
B17 - Igniti --> A22 - ICM
B18 - NOTUSED--> XXXXXXXXXXXX
B19 - ELD --> D10 - ELD
B20 - SCS --> D04 - SCS
C01 - CKP P --> B15 - CKP P
C02 - CKP M --> B16 - CKP M
C03 - TDC P --> B13 - TDC P
C04 - TDC M --> B14 - TDC M
C05 - IAT --> D15 - IAT
C06 - ECT --> D13 - ECT
C07 - TPS --> D11 - TPS
C08 - EGR VLS--> D12
C09 - PA --> NOTUSEDXXXXX
C10 - BKSW --> D02 - BKSW
C11 - MILGRND--> D17 - MAP
C12 - SG2 --> D22 - SG2
C13 - VCC1 --> D19 - VCC1
C14 - SG1 --> D21 - SG1
C15 - VCC2 --> D20 - VCC2
C16 - O2S --> D14 - PHO2S
egreenmachine
Feb 24, 2009 11:05 AM
misternguyen
Nov 16, 2006 12:39 PM
integlspwr2k
Jul 22, 2006 12:04 PM
