Illuminas and Koni Yellows
Quick question, do illuminas and yellows BOTH have adjustable dampening and also spring seat adjustments?
i know that the illuminas have seat height adjustment and yellows have dampening.
any arguments or suggestions? im going for comfort WITH drop. oh, i will be getting GC extended top hats as well.
I could argue against the DC strut bar, but I'm going to assume its a front or rear upper bar, in which case its still a waste of money on a street car, but a desirable "show off" item for most people (besides, a sedan comes with an upper rear bar, its the deck behind the back seat below the window that a hatchback lacks).
Suggestions, sure. Save some money, skip the LCAs, camber kit, and front lower bar. They're all completely unnecessary parts.
THEN i will know if i need to camber kit or not.
oh you didnt comment on the top hats? i take it you agree with me?
i actually might need to camber kit...i've owned an ef hatch and a da both slammed and i had camber problems. once i get the extended top hats i will slam it down as far as i can go comfortably.
But, since you want to slam the car, the camber kit will be a detriment. They're all taller than a stock UCA, further reducing available suspension travel.
I had to raise my car 1" after installing my SPC camber adjusting UCAs, because they were slamming into the shock tower on large bumps that I could safely drive over without the camber kit.
And if your worried about tire wear from camber, don't. I daily on -4* of front camber, no tire wear issues. I doubt you could even get a Honda to -4* without a camber kit. I installed mine so I could run more camber than lowering provided, for competition purposes.
