Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Suspension noise?
Old Feb 12, 2009 | 08:49 AM
_illmatic_'s Avatar
Default Suspension noise?
Hey what up HT, I droped my car 2 inches with Tokico Blues and Neuspeed springs. I've been on this step up for about three months now, and all of a sudden now when I turn my wheel all the way to the left or right, as if I'm trying to back out of a parking space or my driveway it makes a little "poping/bumping" sound. Its not associated with accleration or anything, just when I turn the steering wheel all the way. Its also only the front left side. Any help will be appreacted. Thanks!
Old Feb 12, 2009 | 08:54 AM
Harlowe's Avatar
Function>Fashion
Default Re: Suspension noise?
Sounds like coil binding. It's common with springs. Maybe reseat your springs, might help.
Old Feb 12, 2009 | 09:08 AM
_illmatic_'s Avatar
So you reccommend I should reseat the springs in the strut?
Old Feb 12, 2009 | 09:11 AM
Harlowe's Avatar
Function>Fashion
Hmm dunno, maybe. I had this when I had springs, I never did anything about it though.
Old Feb 12, 2009 | 09:13 AM
_illmatic_'s Avatar
Didn't mess anything up? Just kept making that irritating sound?
Old Feb 12, 2009 | 12:48 PM
EM2_PLo's Avatar
I had the same problem you did when i lowered my car with skunk 2's on tokico blues ...Your strut bearings are probably busted... replace them and the noise will go away ... it worked on mine
http://www.autopartsplace.com/carpar...t-Bearing.html
This strut bearing fits the factory top hat perfectly
Old Feb 14, 2009 | 02:17 PM
_illmatic_'s Avatar
Thanks homie!
Old Mar 12, 2009 | 03:02 PM
gras's Avatar
hey did the noise go away?
I'm getting the same problem. My mechanic said a part of the steering rack which is a mount is busted.
Anyone can elaborate?
I dropped my car about 8 months aback with tein s tech.
Old Mar 12, 2009 | 07:40 PM
01_civic's Avatar
you probably just didn't align it right. just take apart/put everything back together and line up the arrows and it should go away
Old Mar 12, 2009 | 09:22 PM
DynastyRacer22's Avatar
the people at the tire place replaced my strut bearings for me already and the noise is still there sometimes i think you do have to loosen up the bolts on the top and jack the car up and realign it like how 01 civic said
Old Mar 12, 2009 | 09:33 PM
portaman03's Avatar
Does it make the noise while the car is turning in motion or standing still? In motion, might be your axles popping.
Old Mar 13, 2009 | 04:22 PM
gras's Avatar
It makes the noise when car is in motion and sometimes when at stand still.
Also the suspension guy said that my F and R engine mounts needs changing and the 2 big front cradle bushings.
Also the bushing in the steering rack needs changing.
Anyone can elabotate?
Old Mar 13, 2009 | 04:55 PM
likeahstone's Avatar
sounds like your "suspension guy" is trying to make a little doe
Old Mar 14, 2009 | 12:06 AM
tunerkid7's Avatar
i just took mine apart and put it back together and it went away, every once in a while it will make noises or pop, but after a few minuets they go away
Old Mar 14, 2009 | 02:17 AM
thisguyhere's Avatar
Well, I have a pretty similiar situation with the popping noise while I'm driving. I'm pretty sure it's my axle (speedbump).. because I bottom out everywhere ..and I ruptured my cvboot..Hopefully after getting that issue fix the popping may go away.
Old Mar 14, 2009 | 10:01 AM
Jstans84's Avatar
Yeah you might want to get that fixed. Assuming that it is one of your front axle's you are talking about it is easy as hell to replace. I tore my CV boot when I was putting in my TEINs so I just replaced the axle. It was like between 50 and 60 bucks plus a $30 core fee at autozone than you get the $30 back when you bring them your old one. Or you can just pick up a CV Quick Boot Kit for $20 and just repair the boot. But that is your call.
Old Mar 16, 2009 | 08:19 PM
01_civic's Avatar
before u do anything and pay, just take it apart and see if it is properly aligned. if it is and it still makes that noise, then get it fixed. because i had this sound when turning and going over bumps, but after i properly aligned it, the sound went away
elly7b
Feb 6, 2014 04:54 PM
Peruviann83
Jun 7, 2009 09:17 AM
picos
Suspension & Brakes
Nov 26, 2005 11:54 PM
Kouki-EK9
Apr 6, 2004 10:51 AM
