b16 stumbles at low rpms (less than 2k rpm)
Old Feb 12, 2009 | 06:49 AM
Lightsped's Avatar
Default b16 stumbles at low rpms (less than 2k rpm)
Lately when I casually pull away from a stop my car stumbles just as I am letting the clutch out at low rpms (2k rpms or less). It feels as if the motor isn't getting enough fuel. If I rev is slightly (3k or so) as I let the clutch out it is fine, but if I just let the clutch out with barely any gas it stumbles. It does the same at low rpms in 2nd gear....
Maybe I am driving it wrong, or maybe it is dirty fuel injectors? Any ideas? The car is a mostly stock b16 with 128k miles.
Old Feb 12, 2009 | 10:50 AM
twentyhurtz's Avatar
Default Re: b16 stumbles at low rpms (less than 2k rpm)
check ignition timing maybe? when i was tuning my up a little i noticed that when i had my dizzy turned a little too retarted that it would stumble and lag hard at low rpms, then kick it like a bat out of hell at a higher rpm
510bey
Honda Civic (2006 - 2015)
Feb 5, 2019 07:56 PM
Lightsped
Feb 12, 2009 02:59 PM
nengx07
11
Feb 10, 2009 05:38 PM
Exempt
Aug 9, 2007 07:28 AM
p0pe
Mar 14, 2002 09:23 PM
