b16 stumbles at low rpm?
Lately when I casually pull away from a stop my car stumbles just as I am letting the clutch out at low rpms (2k rpms or less). It feels as if the motor isn't getting enough fuel. If I rev is slightly (3k or so) as I let the clutch out it is fine, but if I just let the clutch out with barely any gas it stumbles. It does the same at low rpms in 2nd gear....
Maybe I am driving it wrong, or maybe it is dirty fuel injectors? Any ideas? The car is a mostly stock b16 with 128k miles.
i had this problem with my b18b.... it turned out to be the dizzy. It was not dead but it was on the way out. as soon as i replaced it, the problem was gone, make sure that your timing is the same when you replace it with a new one
yeah i never new they were that expensive until i went out looking for a new one. i found that it is better to get one fron a junk yard or private seller. they are a lot less money and iff they go out again it will only cost you between $75-$100 used.
