Question on Type-R Fog Light switch
Basically I have a jdm type-r fog light switch and it stopped working on me one day but the led light still works on it and I was told I need a relay on it somewhere and the switch burned up cause i didnt have one is that true if so what type of relay do I need and where does it go. If any one has had this problem or knows anything about it please let me know, thankyou.
Running your fogs without a relay is a bad idea. Do it right and you won't have this problem. Here is my write up so you can fix your problem.
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
My brother used to burn out switches ALL the time from the 50W driving lamps we mounted on his Ford Ranger. Finally we wised up and wired up a relay and it never burned out another switch again.
4DRmafia
Nov 9, 2006 09:48 PM
1989CivicSi
Jun 11, 2006 01:28 PM
GS8HFL21
Nov 9, 2005 06:56 AM
