auto trans problem..wont shift to any gear
Old Feb 11, 2009 | 10:52 AM
xhondaaccord92x's Avatar
Icon6 auto trans problem..wont shift to any gear
i have a 92 accord ex with h22a engine and trans... the trans wont shift into any gear and engine wont rev over 3000 rpms and sounds like its under a load but the car isnt moving. the trans has just had a new filter and fluid change. now i get it back together and this is what i get.. any help please
Old Feb 11, 2009 | 11:03 AM
P_Adams's Avatar
Default Re: auto trans problem..wont shift to any gear
I'd be curious as to where the Transmission Filter went.....
Old Feb 11, 2009 | 11:07 AM
The Filter goes inside the trans... it was basically rebuilt
Old Feb 11, 2009 | 12:01 PM
P_Adams's Avatar
Thanks, just checking
Two gear ranges applied at the same time?
The 3k rpm could be all T.Converter slippage.
Any "Check Engine" lamp indicators?
P
Old Feb 11, 2009 | 01:48 PM
the only check engine light i have is code 36 which i have posted on here to and have googled for but no luck finding any answers on that one. the car was running with h22a and prelude trans but had a issue (out of 10 mins driving the car might or might not do this but it was accelerating at a very slow rate no matter how hard i was on the gas, rpms would slowly go up and the car would barely move then hit about 2500 to 3000 rpms and "lets go" and will drive fine and accelerate fast). the car was doin that so i swapped trans back to the f22a trans(stock) still did it.. both trans have been sitting for about a year. so i took apart and cleaned h22a trans replaced filter and just got that back into the car and now its not goin into any gear at all but engine sounds like its under a load.
Old Feb 11, 2009 | 01:50 PM
from above... torque converter has been changed out too but this last time i had f22a trans in with first problem then just swapped trans with cleaned h22a trans and left the torque converter on cuz i new that one is working
Old Feb 11, 2009 | 08:08 PM
so far i have checked the linkage and that is fine. the shift rod is clicking into the gears but the parking pin is not engagin or anyother gear for that matter
Old Feb 12, 2009 | 09:30 AM
Anything...
Vtec04
Transmission & Drivetrain
Dec 17, 2016 09:37 PM
jgauge
Aug 24, 2011 10:06 AM
jkwanus
Jan 29, 2011 04:34 PM
Civic_4life
Nov 25, 2009 06:08 AM
alb_accord
Apr 6, 2004 01:23 PM
