overheating 92'b16a TEG
Old Feb 10, 2009 | 05:54 PM
GSE980's Avatar
Default overheating 92'b16a TEG
My car idle surges from 1k -2k when Im at a stop for more then 5min the temp creeps up . I drive and it goes back down..
Fan not turning on ???
Anybody else have this problem?? What was done to correct it
Old Feb 10, 2009 | 06:01 PM
MumBleZ_94gsR's Avatar
Default Re: overheating 92'b16a TEG
check your coolant
Old Feb 10, 2009 | 06:03 PM
sp00ledbseries's Avatar
Originally Posted by MumBleZ_94gsR
check your coolant
x2
Old Feb 11, 2009 | 09:05 AM
GSE980's Avatar
its full and green no oil....I have a full size radiator instead of the half size one like my del sol is there a chance it could over heat from that and that the fan isn't doing its job because of more volume of liquid to cool
Old Feb 11, 2009 | 12:11 PM
Mindgamez's Avatar
I had the same problem the coolant isnt goin into the block. Where the fan relay goes right above the tranny on the back side of the block theres a plug. Its actally the Thermastat for the block. Replace is and it should let the coolant into the block and cool it.
Old Feb 11, 2009 | 01:06 PM
GSE980's Avatar
R&R thermostat
so its stuck closed and only gettting air cooled.
to follow up on my last question
What does it matter as far as sizes of radiators..?? running hotter or colder??
Ehron
29
Aug 7, 2022 05:46 AM
vlude99
Jul 30, 2009 05:58 PM
Exxel82
Oct 25, 2005 04:33 PM
technine
22
May 9, 2005 12:47 PM
vtec69
Jan 16, 2003 09:24 AM
