Civic Shift Boot
Old Feb 10, 2009 | 05:53 PM
db8int3gra's Avatar
Default Civic Shift Boot
My shift boot don't seem to be mounted all the way up and stay there. It always glides down exposing the ugly stick. I used double side tap and got it where I wanted but when I put it to first....I guess its not long enough. Will a replacement type r boot correct the problem?
Old Feb 10, 2009 | 06:38 PM
lee97ex's Avatar
Default Re: Civic Shift Boot
no as far as i know thats how they are supposed to sit
Old Feb 10, 2009 | 06:49 PM
blueg6's Avatar
on my friends rsx s they have a locking nut or something to hold it up. try looking for something simliar.
Old Feb 10, 2009 | 07:05 PM
BlueIntegraBoy's Avatar
Small zip tie under the collar of the boot will fix your problem.
Old Feb 10, 2009 | 09:12 PM
trustdestruction's Avatar
+1
or a thick rubber band wrapped around the shifter 2-3 times or so. Easier to remove.
Old Feb 10, 2009 | 09:13 PM
93egSLEEPER's Avatar
Originally Posted by trustdestruction
+1
i used electrical tape over a rubberband
Old Feb 11, 2009 | 05:57 AM
94EG8's Avatar
Seagull Management
Thick rubber O-ring, put it on too high and screw the shifter on and it will push down keeping the boot tight against the shifter.
Old Feb 11, 2009 | 06:23 AM
Go_Race_Your_Self's Avatar
Two Piece
Old Feb 11, 2009 | 06:29 AM
db8int3gra's Avatar
Thanks guys.
Old Feb 11, 2009 | 07:09 AM
ej1love's Avatar
i used the zip ties on mine, tried a rubber band a long time ago and it melted cause its so hot here...
Old Feb 11, 2009 | 07:32 AM
DeathLens's Avatar
I have a CTR boot and it stays up. It doesn't show the stick.
Old Feb 11, 2009 | 07:50 AM
EL Vap133's Avatar
Some boots stay up and some start to sit low. I think that plastic ring around the top of the boot cracks. I used the old rubberband/electrical tape trick and it worked fine.
MechEng
Mar 21, 2012 08:51 PM
Cap'N Chronic
Dec 26, 2011 09:57 AM
PatrickGSR94
Apr 4, 2010 09:03 AM
Toe_Knee
Jun 26, 2008 02:25 PM
Gant
Apr 17, 2006 11:26 AM
