How to check Head
Old Feb 10, 2009 | 05:14 PM
Christopherian1982's Avatar
Default How to check Head
What do you look for in a head to see if there are any damages? Are there any physical way to mechanical test a head that's out of the vehicle?
Old Feb 10, 2009 | 05:27 PM
hondamike89's Avatar
Default Re: How to check Head
You talking internally or on a block?
what motor/head?
Old Feb 10, 2009 | 05:33 PM
what motor/head?
b16 head/internal
Old Feb 10, 2009 | 05:48 PM
TheJGB3's Avatar
Take it to a machine shop for a hot tank, and magnafluxing.
Old Feb 10, 2009 | 05:51 PM
^^ do like he said thats your best bet.
Usually the only thing you can do without a hot tank is just check for metal shavings and any wear on the valves/springs. Cams and stuff like that.
Old Feb 10, 2009 | 05:52 PM
hot tank is just to clean everything off correct? What is magnafluxing? And how much would it cost to get it done?
Old Feb 10, 2009 | 05:55 PM
Go here.
http://www.circletrack.com/techartic...ech/index.html
Old Feb 10, 2009 | 06:09 PM
Sounds like alot of money to do a tear down on a head...
Old Feb 10, 2009 | 06:20 PM
yeah. Like i said the way you can do it yourself is by checking for metal shavings cracks/leaks, and wear on the valves/springs. Check the bottom of the head to make sure its all level and no warping is going on.
Old Feb 10, 2009 | 06:25 PM
bossm's Avatar
magnafluxing imo is not worth it if it is a stock head and its on the car running better off replacing your valvetrain then spending the money on stock head
Old Feb 10, 2009 | 09:24 PM
I only wanted to know cause i pulled out my engine to rebuild my bottom end and on the bottom of the head where i believe the valves, there was some build up on them. I believe the build up was on the exhaust side.
Old Feb 11, 2009 | 06:25 PM
Old Feb 11, 2009 | 06:28 PM
bossm's Avatar
take a picture and is this a completely stock motor
Old Feb 11, 2009 | 07:54 PM
joshkx's Avatar
interesting about magnaflux
mhewitt
Oct 26, 2011 12:00 PM
laziebun
Oct 1, 2008 06:32 AM
MrPscott
Jul 5, 2007 04:26 PM
Unjockable
Jan 25, 2005 10:50 AM
