advice on hobart tigmate
i am looking into getting a tig welder, as i already have a mig (hobart handler 140) which i just use for hobby projects in the garage and has served its purpose very well. now i want to try and fab a few manifolds, and exhaust components as a garage hobby. the welder i am interested in is the hobart tigmate, im just wanting to see if anyone has any comments about this machine?thanks for any help
yea your right about that.i have a 180sd its like 3 years old now.so used you could find one for around 800 or less.im not sure if the tig mate has ac?for a good hobby unit you would want ac so you could do some al.
the tigmate does have ac, and the diversion 165 and tigmate are the two i have been comparing together. i havent really looked for a used one yet but that is something i will keep in mind, and start looking around as well.
You might not find a used Diversion since they just came out this last year.
i know thats fairly new, and i was trying to compare the two while i was at work, and from what i could see the tigmate and diversion werent to much different.
I have a hobart tigmate does the job i have welded a ton of things but am looking to upgrade in the future. Deffinetly not a bad machine to start off with but if ur not in a big rush just save up a few more bucks and get you self something better ,One thing i dislike about it is its aircooled torch and limit to amp's.
i just bought a diversion 165 ait should be coming tomarrow, as for the tigmate i think its the same as the econotig, and i dont hear very good reviews about the econoti, as for the Diversion 165 i hear great reviews for the hobbiest and small jobs. if you nee somethign more i owuld go for the miller syncowave or the TA-185
alright so the tig mate has ac.i couldnt remember if it did.there was one at a shop i worked at.i never welded with it.i have used the econo tig.it was not to bad.it had a really crappy start function.also these two machines are a little short on amps but if the price is right i would think it would make a good hobby machine.
thats really all im looking for right now is a machine for hobby projects, but if there is something that is good for that and may allow me to grow with it and do some bigger projects would be great to.
the only thing that the 14o amp machine is down on is welding thicker aluminum.other that that the 140 will do all that you need it to.if you where to find a 180sd you would have a more user friendly machine with better high freq start and you could weld a bit thicker aluminum.also look at the thermal arc 185 inverter.they are very nice welders too.
99_red_si
Sep 5, 2007 09:15 PM
ci_v_ic
11
Jul 24, 2006 07:33 PM
