Brake pad rumor...?
Old Feb 10, 2009 | 04:03 PM
tacpsi's Avatar
Default Brake pad rumor...?
i just bought a front and rear set of EBC dimpled/slotted rotors and i have heard using ceramic pads are bad on slotted/drilled/dimpled rotors...? is this true? is there a certain pad you should use...?any help would....help!
Old Feb 10, 2009 | 04:48 PM
joshkx's Avatar
Default Re: Brake pad rumor...?
ceramic is actually a softer material tham semi-met, so i dont think it will have any affect on the slotted/drilled rotor..... if ur more of a street racing type, u will have to go with semi met...........
Old Feb 10, 2009 | 05:59 PM
Christopherian1982's Avatar
x2
Old Feb 10, 2009 | 06:28 PM
tacpsi's Avatar
well i brake hard does that make a difference?
Old Feb 10, 2009 | 06:31 PM
93egSLEEPER's Avatar
get semi metallic pads. they last longer and dont heat up as fast. overall better performance. hawks hp+ or hps is what i reccomend
Old Feb 10, 2009 | 06:34 PM
tacpsi's Avatar
^^^thanks bro
Old Feb 10, 2009 | 06:41 PM
iliv2xlr8's Avatar
Hawk HPS's FTW!
They are a great street/track pad!
Old Feb 10, 2009 | 07:15 PM
D50boy's Avatar
Originally Posted by iliv2xlr8
Hawk HPS's FTW!
Just got all 4 corners for $123 to my door from buybrakes.com
Old Feb 11, 2009 | 02:54 AM
iliv2xlr8's Avatar
Sweet!
I should have told you to check ebay. I got them for $90 shipped....
Oh well, you will like them.
Just make sure you break them in properly.
Old Feb 11, 2009 | 07:06 AM
tacpsi's Avatar
^^break in brake pads....i take it that is slamming on them a few times...?
Old Feb 11, 2009 | 11:30 AM
D50boy's Avatar
Resurface the rotors and make about 10 stops at about 40 MPH with moderate pressure on the pedal.
Old Feb 11, 2009 | 12:25 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
lol what does that even mean?!
EBC's greenstuff and redstuff pads are ceramic. I'm sure they wouldn't make a street rotor that's incompatible with their own street pads. The only reason I could think of not using a ceramic pad on a slotted rotor is because ceramics are more brittle, and therefore more likely to crack when the slot crosses over them.
But then again, a lot of OEMs use slottled/drilled rotors with ceramic pads.
You should be fine either way.
No. It means whatever the manufacturer says break in period means. There will usually be a break in procedure.
Some pads do not include a break in procedure. You usually drive them normal for the first few miles, then do a few hard stops. Then park the car with the E brake off for around 15 mins so they cool back off.
Old Feb 11, 2009 | 02:35 PM
tacpsi's Avatar
thank you, helps a lot
Ash J. Williams
Suspension & Brakes
Sep 26, 2012 06:23 AM
fastboy559
May 26, 2009 05:21 PM
ArtificialSynapse
Mar 20, 2007 08:04 AM
Arsenal
Nov 30, 2006 12:50 PM
vlc92189
12
Sep 12, 2006 05:08 PM
