prelude injectors
i have tried searching but find its a load of ish with this v bulletin thing now.
question is can i fit injectors from 93 2.2 vtec prelude into my itr engined eg hatch,
i know that they FIT IN as such and that i will need to change the plugs.
thing is the prelude injectors are peak and hold instead of the usual saturated type.
can they be swapped? i have a power fc if there are any changes i need to make wiht that could someone please let me know.
thanks.
thanks.
Yes, you can use them just get a resistor box and wire it in. Unless you can swith the injector signal with the fc i dont know. Id just use a resistor box form a civic, if yo uneed on let me know i have a mint one.
thehondaguru
Feb 14, 2004 04:32 AM
