1993 honda accord transmission problem
Old Feb 10, 2009 | 02:28 PM
hgb420's Avatar
Default 1993 honda accord transmission problem
I have never had this happen to me before. I was driving home on the freeway and all of a sudden it felt like the car went into neutral. I had some power, but it was like it just lost the gear it was in revving the engine high. WhenI shift to D3, D4 which was the gear I was in, stays lit up as well as D3. Also if I shut the car down for a couple of minutes, and start it again, I can drive for about a block or two and everything is ok. Right after that it does it again. Same thing over and over. I checked the fluid while the car was running, and the level was ok. Does anyone know what could cause this???????? Please help!
Old Feb 10, 2009 | 02:37 PM
thadelsolryda's Avatar
Default Re: 1993 honda accord transmission problem
hey bro first of all you need to check the transmission fluid when the car is off and also is there any cel's
Old Feb 10, 2009 | 03:22 PM
hgb420's Avatar
i checked it while it was off too. i was told to check it while it was running. it was ok both on and off. i am not exactly sure what cel's are
Old Feb 10, 2009 | 08:19 PM
hgb420's Avatar
Can anyone please HELP??????
Old Feb 11, 2009 | 06:21 AM
you check it when it is off and a cel is a check engine light
Old Feb 11, 2009 | 08:35 AM
hgb420's Avatar
I checked it while it was off, and I do not have any check engine light on. I have noticed that the cruise control seems to work intermittantly also. I don't know if this is related or a whole seperate problem. Possible the tranny speed sensor?
Old Feb 11, 2009 | 09:15 AM
hgb420's Avatar
I just got off the phone with a transmission guy and he told me something in the tranny blew up and shreds of metal are blocking the filters while it is running. When the car is off the metal falls out and settles causing it to be ok for a minute till the filters get blocked again. Thanks for your help! Time for a new car.
joe8mofo
Dec 24, 2023 11:16 AM
Fastcat314
Aug 17, 2017 12:05 PM
mrdon213
Transmission & Drivetrain
May 24, 2017 09:45 PM
miguel11691
Mar 6, 2012 10:58 PM
brianjung818
Jan 16, 2010 05:59 PM
