Can't get rid of code 14??
Old Feb 10, 2009 | 01:58 PM
Jonathan_ED3's Avatar
Default Can't get rid of code 14??
Bone stock '93 D16Z6 engine in OBDI civic.
I'm getting a persistent code 14. I have been all the way through the OEM Service Manual flowchart -- valve has power with key "on", continuity checks out okay for ground and power, valve clicks when I connect A9 to A23, I have replaced/switched the IACV with a known working unit from my daily driver, and have also tried two known working P28 ECU's.
As most of you know, the end of the flowchart is "replace IACV; replace ECU". Well I got to the end, done both, yet the code persists!
Can anybody point me in a new direction? I have done rigorous searching on H-T, Google, and pretty much every Honda forum with no good info.
It's making my car nearly impossible to drive. I can't even set the timing or do other stuff because the car won't fully warm up and I can't get the CEL off.
Thanks for any light you can shed on this!!!
Old Feb 10, 2009 | 02:36 PM
ralph11sec's Avatar
Default Re: Can't get rid of code 14??
you said you tried replacing the iacv as well as the ecu and it still checks up?
retain the iacv.
change the ECU. does it still light up?
Old Feb 10, 2009 | 05:49 PM
I tried old IACV with old ECU, old IACV with new ECU, new IACV with old ECU, and new IACV with old ECU.
Same result everytime. Runs for about 10 seonds and the CEL 14 comes on.
Old Feb 13, 2009 | 01:18 PM
Any other ideas?
Is there more in the Idle Control system than just the IACV? I don't understand why I can't get this code away.
Justin4
Engine Management and Tuning
Jan 29, 2010 08:14 PM
duh blacksheep
Dec 13, 2004 07:54 AM
carnifex
Oct 1, 2004 10:28 AM
aglswapbuffers
Jul 23, 2004 06:33 PM
