Work Emo Cr Kai + Spoon Cali?
Ok just wanna check, check again, double check to make sure this will work.
I have the Work Emo Cr Kai 17x8 +47 at the front and after all the research i think i have this correct. If i want to use the Cr kai +47 with spoon cali i would need a +10mm spacer? Is this correct? I don't want to spend the money and find out that i need a higher mm spacer. Also if i was to do this i would have to roll my fender or do some high camber setting like -3 or something higher right?
Cool Cool Island Breezes. BOY-EE
you may not need a spacer. If you use a spacer, you will need to mod the fenders or run a ton of camber.
Alright I have confirmed for sure Work Emotion CR Kai 17x7 +42 offset will fit with a +6mm spacer.
Assuming you are talking about spoon calipers here.
So if you wanna run 17x8 +47 you will need a spacer, and a 10mm one should cover it. You're wheels will stick out of your fenders but I would not add any camber. Just roll the front and don't slam it.
All you needed to do was find the Spoon fitment guide thread created by yours truly. CLICK HERE
YoungMoneySi
Oct 1, 2007 04:04 PM
