How do you check mechanical timing and compression
Old Feb 10, 2009 | 01:53 PM
97civic07gsxr's Avatar
Default How do you check mechanical timing and compression
I don't know how to do these things and i think i need to do them. someone?
Old Feb 10, 2009 | 02:01 PM
joey1320's Avatar
Default Re: How do you check mechanical timing and compression
i would suggest you pick up a helms manual...
Old Feb 10, 2009 | 02:36 PM
Former User's Avatar
Here's how to do the compression tests:
http://www.hondacivicforum.com/forum...ad.php?t=40559
Old Feb 10, 2009 | 02:37 PM
Is your engine SOHC or DOHC?
Mechanical timing for SOHC: Remove valve cover and upper timing belt cover. Use a 17-mm socket and ratchet to turn the crankshaft pulley counterclockwise until the camshaft gear is oriented precisely at TDC1 (see diagram). With the cam gear in this position, the white TDC1 mark on the crankshaft pulley should align precisely with the pointer (see diagram). If not, the mechanical timing is OFF.
Old Feb 10, 2009 | 05:04 PM
joshkx's Avatar
wow, interesting....
sde780
33
Jan 7, 2011 08:37 PM
Adj
Jul 14, 2009 11:07 AM
todapower
Apr 11, 2006 01:42 PM
crxgsr91
30
Dec 10, 2004 11:12 AM
Malgerus
Jun 25, 2002 08:17 PM
