Hit a curb
Old Feb 10, 2009 | 11:41 AM
The93egg's Avatar
Default Hit a curb
Ok i hit a curb with my rear right wheel. The whole wheel has alot of positive camber. I took the wheel of the check the problem, and the drum brake is bent inward causing the positive camber. Im not 100% sure on what i need to replace? Just the drum brake?
Hill4589's Avatar
Default Re: Hit a curb
take a few pics and post that should help a lot
Old Feb 10, 2009 | 11:47 AM
adam00's Avatar
you should just swap to rear disc now
Old Feb 10, 2009 | 11:49 AM
1LowSol's Avatar
Good Idea.
Old Feb 10, 2009 | 11:50 AM
90Rexx's Avatar
you probobly just bent your lower control arm.... no need to replace your brakes lol....
Old Feb 10, 2009 | 11:53 AM
SiYouLater's Avatar
When everything is fixed, get an alignment.
Old Feb 10, 2009 | 01:22 PM
H22Ej1's Avatar
Shenanigans
youll most likely need to replace the lca and trailing arm post pics and we could be able to tell you for sure
Old Feb 10, 2009 | 01:34 PM
Agent_EM1's Avatar
Exactly what I was thinking
Old Feb 10, 2009 | 02:36 PM
ALLxMOTOR EG's Avatar
Vietnamese!
good thinking
Old Feb 10, 2009 | 03:31 PM
qwrty's Avatar
rear disc conversion
+1!
Old Feb 10, 2009 | 03:35 PM
93egSLEEPER's Avatar
x2. might have a bend strut perch as well depending on the suspension you are running. you shouldnt have to touch your brakes
Old Feb 10, 2009 | 03:36 PM
kaiba's Avatar
Worst come to worst. You bend your subframe.
Old Feb 10, 2009 | 04:59 PM
joshkx's Avatar
its best if u jus get a new knuckle....ur knuckle might b bent but u cant really tell a difference.....
Heru-Ek
Suspension & Brakes
Aug 14, 2013 06:41 AM
singlehx
Sep 12, 2009 09:04 PM
klomast3r
Sep 6, 2005 08:40 AM
BigZ88
27
Jan 6, 2005 08:53 PM
deeksmooth
21
Dec 13, 2003 01:05 AM
