Name that Turbo! need lil help on Identifying
Old Feb 10, 2009 | 09:49 AM
ESP.net's Avatar
Default Name that Turbo! need lil help on Identifying
What I know... so far, Compressor Housing reads A/R .60, Exhaust Housing under the T3 flange reads .63. Back of Compressor Housing is stamped CCE50, which is a Precision stamping. All parts are new, builder of the turbo pieces new parts together, works on Garrett and Garrett a like quality turbos only. Uses same internals for all turbos he carries, same warantee.
Box came in reads...
T3-To4e Dry C+R .63 T/HSNG Stage 3 54... Gated, V. Band Exhaust.......
I was told it was a 57 trim. However my main question is can a 54/57 trim internal fit in a 50 housing?
As the picture below shows as the funnel effect gets before the fins about an inch it opens up bigger... does this mean theres a bigger 54/57 internal in the 50 housing? Possible?
Yes last step is to take it apart.
Old Feb 10, 2009 | 09:51 AM
Joseph Davis's Avatar
Default Re: Name that Turbo! need lil help on Identifying
Doesn't look like a .50 trim, but the eyeball micrometer is about as good as the butt dyno sometimes.
Measure inducer and exducer diameter of the compressor, done deal.
Old Feb 10, 2009 | 10:57 AM
Importrev's Avatar
Looks like a PTE-SCM50. Nice turbo.
Old Feb 10, 2009 | 11:26 AM
ESP.net's Avatar
The compressor housing/inlet, where it has been shave down where the fins of the wheel are 57.53mm it appears, micrometer, I took a feeler gauge to measure the distance between the wall and the fin on each side roughly 5 thousandths. Subtract 10 and you get 57.25mm which would be a close identication that the compressor is a 57 trim? No way my measurements would be off enough to net me a 54...
Old Feb 10, 2009 | 12:06 PM
project dc2's Avatar
... hrmmm ok ... you have to take off the compressor housing and measure the inducer by exducer to get the trim
not measure the inlet /od of the inlet wheel
THATS how you get the millimeters of the wheel not the trim .
however thats an entire diff ballpark
Old Feb 10, 2009 | 12:08 PM
1. Wheel trim topic coverage
Trim is a common term used when talking about or describing turbochargers. For example, you may hear someone say "I have a GT2871R ' 56 Trim ' turbocharger. What is 'Trim?' Trim is a term to express the relationship between the inducer* and exducer* of both turbine and compressor wheels. More accurately, it is an area ratio.
* The inducer diameter is defined as the diameter where the air enters the wheel, whereas the exducer diameter is defined as the diameter where the air exits the wheel.
Based on aerodynamics and air entry paths, the inducer for a compressor wheel is the smaller diameter. For turbine wheels, the inducer it is the larger diameter (
Example #1: GT2871R turbocharger (Garrett part number 743347-2) has a compressor wheel with the below dimensions. What is the trim of the compressor wheel?
Inducer diameter = 53.1mm
Exducer diameter = 71.0mm
Old Feb 10, 2009 | 12:15 PM
ESP.net's Avatar
correct the inducer is what I did measure and it was 57.25 mm roughly... not the exducer...
is there a given # on the exducer if my inducer is 57.25mm? Obviously Precision/Garret internals.
Old Feb 10, 2009 | 12:26 PM
extralargenog's Avatar
Looks indeed like a PTE turbo John.... SC50.... It will be PERFECT for your car.
Old Feb 10, 2009 | 12:51 PM
alexsracing's Avatar
looks like a sc50 compressor, ive had a precision 50 trim before. just havn't seen the internal gated version
Old Feb 10, 2009 | 01:31 PM
ESP.net's Avatar
bump still figuring this turbo out
Old Feb 10, 2009 | 05:09 PM
ESP.net's Avatar
Compressor Housing/Turbo inlet
Inducer 57.40mm
Exducer 82.04mm
My math says 49 trim/50 trim
still trying to compare this to something that is currently offered from Garrett or Precision
Old Feb 11, 2009 | 08:27 AM
ESP.net's Avatar
New info:
Turbonetics Ts04 T series wheel is real similar to what I have?
Mine 2.260" 3.230" 49/50 trim math comes to
TS04 30335 2.300" 3.304" 20450 4.000" (T series big shaft) 49/50 trim match comes to
Old Feb 11, 2009 | 09:43 AM
TheShodan's Avatar
Moderator
Garrett & Precision use the same part for their smaller applications per their contract agreement. You're going to receive the same information as the others have already said.
Old Feb 11, 2009 | 10:09 AM
ESP.net's Avatar
the standard precision 50 trim has 2.123" ind and 3.000" exd
Now being that I have a 50 trim thats 2.260" ind and 3.230" exd bigger wheel, doesnt mean the turbo will have more top end as well? Flow more. Compared to a standard 50 trim? in theory wouldn't spool up as quick as the std precision 50 trim above, being a bigger wheel but it would flow more at top end looks to be as much as a 57-60 trim?
Old Feb 11, 2009 | 01:30 PM
TheShodan's Avatar
Moderator
Not necessarily. At these levels of measurement, (which can easily be off by a couple of hundredths easily) you're splitting hairs here. You measured the wheel with housing off, correct?
Old Feb 11, 2009 | 02:52 PM
ESP.net's Avatar
Yes the above measurement is with the cover off with a mic, measuring wheel inducer and exducer, it is a bigger wheel over the std. 50 trim it appears more like to be like a super 60 type deal from what a local turbo guy here thinks, big wheel smaller housing 50 housing.
Old Feb 11, 2009 | 05:41 PM
TheShodan's Avatar
Moderator
That's your call. Precision usually has numbers/letters on the backside of the compressor cover and on the compressor outlet that goes to the intercooler piping. check those places as well.
From your pictures it looks like a 50 trim, bottom line. GL. We found it, named it, done with it.
Old Feb 11, 2009 | 06:42 PM
ESP.net's Avatar
correct housings 50 trim wheel is a big wheel, like I mentioned it's closer to a super 60, guy who puts these together is a builder all new parts, all hot specs for decent builds,
ntoxicatedtigah
Mar 24, 2009 07:22 PM
Dee
Feb 28, 2005 05:53 AM
95IntegraGSRAZ
Apr 27, 2004 09:02 PM
booscivic
Dec 15, 2003 07:14 PM
B20bTurbo
May 8, 2002 10:11 PM
