Strange problem:99 GSR not turning over
Car won't turn over. It won't even try. The battery and electrical seem to be fine. All dash lights and stereo come on. I can hear the fuel pump. Turning they key yields no telltale sounds like a clicking or grinding. I'm getting....Nothing. Any ideas?
Yeah, Fuel pump is priming. Everything else comes on (lights in dash, radio). I will have to llok at the relay a little better when I get home. Thanks : )
Check your battery terminals. After i put my ITR/GSR swap in my car, everything powered on and sounded good, but turn the key and nothing happens. No sound, nothing. Replaced the terminals because they weren't grabbing tight enough. Try that, then check your tranny ground, valve cover ground and thermostat housing ground. Check the starter ground too.
Keep us posted.
Keep us posted.
i had that problem somehow it pushed the pad that pushes the clutch switch out of the pedal. turn the key all the way like its running and take a screwdriver and touch the big thick wire post and the shrouded signal wire at the same time see if it fires up and runs if its the main relay it shouldnt run or stay running
bts_22
Oct 6, 2024 05:54 PM
Xextr3meX
Nov 6, 2018 11:55 AM
jdmekrobot
Jul 3, 2009 06:20 PM
