Does any body here know everything about ej/eg honda's???
Old Feb 10, 2009 | 07:00 AM
LSXFEIND's Avatar
Default Does any body here know everything about ej/eg honda's???
OK here my situation, first of all I have a 93 EX coupe, I dropped in a 1991 D15b2 in it then converted it to a OBD1 with the manifold and harness and dizzy, running a P28ECU, tried to start it, everything turned over nicely and sparked and fuel pump was pumping injectors where injecting, it almost did start, so I went to go tighten all the grounds and etc, as i went for the cable that you screw on to the altenator that goes from the harness "I FORGOT TO DISCONNECT THE BATTERY" as i was tightning it i hit the fuel rail that caused a spark and everything to F'UP, went to check for power...nothing, replaced some fuses from the dash and the engine bay especially the Black A 80..everything turned on again except the fuel pump doesnt turn on and theres no spark????? I CHECKED THE PUMP CONNECTED IT STRIEGHT TO THE POWER WITH A KILL SWITCH ITS WORKS!!!....CHECKED THE MAIN RELAY WITH MY FRIENDS HONDA IT WORKS AS WELL!!!!, LASTLY I CHECK THE ECU AND THANK GOD IT WORKS PERFECT STILL!!!!!!!! I have check a bunch of wires with my multi meter and the one that seems to be messed up is a yellow wire with a green line on it. i believe thats the one for the fuel but i dont know what the hell to do is it a short!!??????????? PLEASE HELP THANK YOU!!!!!!
RichCMemphis
Mar 3, 2014 06:16 PM
RecklessEJ
15
Sep 18, 2011 03:56 PM
92nahatch
Nov 10, 2009 09:09 PM
LSXFEIND
Feb 7, 2009 07:18 PM
rizzob
Aug 20, 2006 07:03 PM
