help 93 eg wont start..
didnt start..played around with it more and started to get no response (not turning (fuel pump is not turning on) checked all grounds, their ok .what could this be?...the fuel pump will not turn on?? any help is appreciated, thanks guys
starter is fine, main relay is fine, rizzob
Re: help 93 eg wont start.. (rizzob)
try replacing the fuel pump or make sure that the pump is plugged in. on ur grounds make sure that u sand it down to the metal so theres no paint between it. make sure the ecu is plugged in. make sure the ground is connected on the back of the block right above the tranny where the fan temp sensor is. what were u doing to the car to make it all of a sudden not work or did it just stop working all of a sudden
Did it cut off while running?
Or did it just refuse to start one day?
If the engine is not turning over, make sure you have enough battery power avalible. That includes the cables that connect to the battery.
Could it be his main relay?
Check ALL of your fuses too.. just so you can eliminate them as a source of any problem.
Re: (Paprika)
it turning over but not starting bought the car this weekend the guy told me under the colum near fuse box wiggled some wires and then the fuel pump came on he siad you have to do that some times but he couldent find the source. when i took it off the trailer i just wiggled some s and it started. that was yesturday tryed it today and it woudnt so now im at a lose not battery something involving fuel pump or something under dash... robb
whasian
11
11-07-2013 02:53 AM
KiDDD...
51
08-28-2011 03:44 PM
97civic07gsxr
21
02-08-2009 02:33 PM
