H2B which alternator belt?
Old Feb 9, 2009 | 06:33 PM
nightrider93ex's Avatar
Default H2B which alternator belt?
what belt am i supose to use on an h2b set up?....i have an alternator pulley with 4 teeth and a crank pulley with 5 teeth..
Old Feb 9, 2009 | 07:02 PM
cdownin's Avatar
Default Re: H2B which alternator belt?
I think you prolly have the JDM h22 pulley.. I think there are 4 teeth but its a five rip pulley.. If you have the stock alternator bracket.. I think you should be okay with a 38 inch 5 rib pulley... or if im wrong about the teeth get a 4 rib 38 inch...
Old Feb 11, 2009 | 07:51 PM
RotiEatter's Avatar
Ditto
I took some zip-ties and made a belt to size I needed and went to the auto store. Then I matched up my homemade belt to real belts and found the best size. Worked fine, yee.
angryhillbilly
Jun 2, 2015 05:40 PM
ubermoc
Feb 9, 2008 09:05 AM
HondaRexBoi
Apr 4, 2007 09:49 PM
incubus
Mar 10, 2004 08:33 PM
