my ej1 bogs at low rpm
Old Feb 9, 2009 | 04:53 PM
nengx07's Avatar
Default my ej1 bogs at low rpm
everytime i start first gear n release the clutch the car begins to go but bog at low rpm(sound like a subaru) then when i past 2k rpm its go smoothly........it does that for every gear if im close to 2k or less rpm....its seems like it not getting enough fuel or sumthing.......i added lucas fuel injector cleaner n seamfoam it......still the same thing......
Any Advice.......
Old Feb 9, 2009 | 11:11 PM
b18turbo210's Avatar
Default Re: my ej1 bogs at low rpm
u too. i just put in a gsr in my 96 civic dx and i am haveing same problem but when i floor it it goes all the way to 8k like nothing with vtec working and no bogging but at low rpm it souds like a subby even on the freeway when its coasting.tried diff injectors,plugs,wires,dizzy and still problem remains any help
Old Feb 9, 2009 | 11:13 PM
also forgot to add that mine does it under 4k rpms only-
Old Feb 10, 2009 | 04:00 AM
nengx07's Avatar
bump
Old Feb 10, 2009 | 07:46 AM
joshkx's Avatar
my instructor told me that it might b ur ignition timing.....lol.......
Old Feb 10, 2009 | 07:49 AM
boarding2008's Avatar
Did you recently do the timing belt?? B/c i had the same prob with my b18b1 when i did mine, it would almost want to stall when i gave it gas then start to go. but the crankshaft was off one notch, i fixed that and it doesnt do that anymore.
Old Feb 10, 2009 | 07:51 AM
it could be that too.did you mess with the dizzy at all?
Old Feb 10, 2009 | 07:53 AM
AWDxBOOST's Avatar
check the timing with a light and tell us what it says
Old Feb 10, 2009 | 08:00 AM
xbigpitax's Avatar
i had this problem in my old old sohc check and see if the wires from the distributor r bad... i changed mine 2 9.0 and the bog went away
Old Feb 10, 2009 | 08:03 AM
z6hatchboy's Avatar
when you check it with a light, it should be at the middle mark
Old Feb 10, 2009 | 04:39 PM
joshkx's Avatar
oh i readjust my ignition timing.....loosen the distributor n tilted it to advance n it jus didint bog after that.....
Old Feb 10, 2009 | 05:38 PM
nengx07's Avatar
it was my ignition timing.. it works fine now =D.. the little tweak on distributor to advance helped
GSR15
May 18, 2013 01:20 AM
`chrisb
Feb 26, 2008 03:33 PM
DCnotTHEshoes
Oct 20, 2005 05:19 PM
yallgee
Sep 22, 2005 04:04 PM
professorman
Nov 18, 2004 07:32 PM
