still ticking after valve lash adjust....help!
Old Feb 9, 2009 | 09:57 AM
Ryanwill86's Avatar
Default still ticking after valve lash adjust....help!
so i have been having a ticking noise from my head after a miss shift recently so i had a valve lash adjustment done and its still there....... im wondering now if its a cracked retainer or some other loose part it the head??? the car runs fine so its not a bent valve and i have no power loss it just ticks like a son of a bitch. anyone have a fix for me you something else to try?
Old Feb 9, 2009 | 10:22 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: still ticking after valve lash adjust....help!
the GSR in your sig?
Is it consistent, like a valve tap? Could be a LMA issue as well. Try jumping your VTEC solenoid and see if the noise goes away.
Old Feb 10, 2009 | 04:44 AM
J.Berta's Avatar
+1. those things get worn over time.
Old Feb 10, 2009 | 05:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
How exactly do you do that? Is it safe to do that with the engine idling? I have a slight tick I'd like to track down myself.
Old Feb 10, 2009 | 05:31 AM
SPOOLINmatt's Avatar
it might try to switch on if you jump the vtec solenoid, you may want to set your idle with a tool or something at around 3500 and then try it...vtec needs oil pressure
Old Feb 10, 2009 | 09:07 AM
Ryanwill86's Avatar
how do i jump the vtec?
Old Feb 10, 2009 | 09:31 AM
Evs-One's Avatar
Solbros Owns Me
screwdriver to hold idle around 2k....unplug VTEC sol and jump to +12v. Should be enough oil pressure to move the timing pistons and engage vtec. Idle will change, but will run just fine.
Old Feb 11, 2009 | 09:35 AM
Ryanwill86's Avatar
what is this doing exactlly? and not to sound dumb but i still dont understand what im doing. also i have been having idle problems and whin u un plug my tps its runs fine just no vtec...what does that tell you???
Old Feb 11, 2009 | 09:49 AM
Ryanwill86's Avatar
ttt
Old Feb 11, 2009 | 12:06 PM
Community Builder
The LMA's are positioned under the middle of each VTEC rocker arm (8 in all) and keep the VTEC rocker arm from flopping around freely while VTEC is not in use. It makes the rocker arm push against something spring-loaded, like the valves, since the middle VTEC lobe on the camshaft is always pushing against that rocker arm whether VTEC is engaged or not. If one or more LMA's goes bad, it can cause a ticking sound.
Old Feb 13, 2009 | 01:32 AM
Extradition's Avatar
And how do U tell either visually or mechanically that an LMA has gone bad?
Old Feb 14, 2009 | 11:15 AM
dadrought6's Avatar
did you adjust the valves when the motor was cold or hot?
ki0326
Engine Management and Tuning
May 29, 2012 10:43 PM
ArmaanOG
Apr 8, 2009 03:16 AM
dc2typer01
Oct 16, 2006 08:55 PM
acurateg96
Feb 6, 2006 03:24 AM
dsosa51
Jun 2, 2004 10:35 AM
