GSR tranny swap on LS
Old Feb 9, 2009 | 08:56 AM
rgaray's Avatar
Default GSR tranny swap on LS
Need info on this swap. Will everything on my LS tranny bolt right up to a GSR tranny? Axles, VSS sensor, starter, etc...
I tried searching, but search function is down.
Old Feb 9, 2009 | 08:59 AM
mpls's Avatar
Default Re: GSR tranny swap on LS
yes it will as long is its hydro to hydro or cable to cable
mouab18c1's Avatar
you will need different axles. speed sesnor is the same and you will need a vtec starter..correct me if im wrong
Old Feb 9, 2009 | 09:05 AM
sp00ledbseries's Avatar
axles are the same im not sure about the starter though seems like my buddy had problems with his starter im not sure
Old Feb 9, 2009 | 09:13 AM
mpls's Avatar
no there all the same axle starter from 90-01 integra
Old Feb 9, 2009 | 09:16 AM
mouab18c1's Avatar
are you sure? from 94-01 trannys are hydros not cables anymore
Old Feb 9, 2009 | 09:24 AM
mpls's Avatar
i know what i'm doing been there done that
Old Feb 9, 2009 | 09:38 AM
i was thinking they were all the same. only difference is between auto and manual
Old Feb 9, 2009 | 09:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
starter and VSS are all the same, VTEC and non-VTEC. The only difference between the axles is the presence of the ABS ring on GS-R axles.
So it should be a straight bolt-in swap.
Old Feb 9, 2009 | 10:05 AM
rgaray's Avatar
So, basically everything I had on the LS tranny, right? Do you have a pic of this ABS ring? Just curious...
Old Feb 9, 2009 | 10:19 AM
Community Builder
It's just that little toothed ring that sits right behind the hub when the axle is in place. If your LS has ABS then your axles already have this. But basically it's a non-issue since we're talking about a GS-R tranny in an LS.
Old Feb 9, 2009 | 10:43 AM
super jdm yo's Avatar
pretty much now all the axles you'll buy will have the abs rings on them. because there won't be a difference if you have the rings and don't have abs. but yeah you're just going to change out the transmission as long as it's the right one, hydro or cable.
Old Feb 9, 2009 | 12:07 PM
delbert's Avatar
everything is the same.
Old Feb 9, 2009 | 01:04 PM
rgaray's Avatar
Cool, thanks fellas!!!!!
Any other things I should change while I have the tranny out? The clutch is fairly new, and so is the slave cylinder.
Old Feb 10, 2009 | 10:54 PM
dc-2_mike's Avatar
cool i was curious as well
im about to attepmt the same swamp next week cuz my 3rd on my ls is completly done and i herd it always happens to ls's so im going with gsr now
effg714
Mar 28, 2008 10:59 AM
1 Fly SI
Nov 10, 2007 05:21 PM
IowayRUlz
Nov 13, 2005 10:38 PM
GSRCRXsi
Dec 10, 2004 08:13 PM
ThaSpitefulWun
Mar 15, 2004 03:02 PM
